R50/53 Auto drop minimal on driver
Old May 28, 2024 | 06:06 PM
wizITup_'s Avatar
wizITup_
So the auto drop on my driver door goes down maybe 1 mm, passenger works as it should ~10mm. If I manually push the glass down once the door is open and close it, the glass auto ups to fully sealed. I have searched on here, but no one seemed to have this same issue, maybe did a bad search. I tried the reset on page 32 of the manual as well as the you tube vids. I just bought the tool for the large cogs. Do i need to adjust via those? Do I need a new regulator? Will a battery disconnect fix everything?
Old May 28, 2024 | 07:24 PM
noodlesandsam's Avatar
noodlesandsam
You can try a battery nap. The cogs will not change the drop behavior. I had my original drivers side die in 2022. ( Feb 05 ). I put a used OE in. No issues, but I learned about the cogs, and that will not help.
whittgu3
Nov 20, 2023 12:16 PM
hoonu
R59 :: Roadster Talk (2012+)
Jun 14, 2023 06:05 AM
1200tec
R55 :: Clubman Talk (2008+)
Sep 27, 2009 05:41 PM
sdavid01
Electrical
Feb 12, 2009 07:57 PM
davn8r
14
May 16, 2005 07:26 PM
