R50/53 Another battery alternator thread
Old May 23, 2024 | 03:51 PM
wizITup_'s Avatar
wizITup_
Just picked up my first mini, 06 S with 70k. Service has been kept up fairly well. Prior to my purchase the alternator was replaced for a 2nd time in the 70k. The battery was replaced 2 years ago with a DieHard platinum AGM.
When I hard accelerate with the AC on the battery light kicks on until I let up. If the AC is off l, no battery light. The light doesn't come on at idle. Power steering seems fine.
I checked the voltage with a gauge in the cig lighter. 13.7 at idle. 13.1 with AC on, sometimes dropping down to 12.5. I charged the battery up to 12.75, shortly after it settled at 12.3. After a drive it settles at 12.3.
I have a 15% reduced pulley. it seems like the car was built with having an underpowered alternator - cases of PS pumps going out when the alternator dies. So is the issue with the new alternator or something else?
Thanks all!
Old May 23, 2024 | 04:30 PM
Here2Go's Avatar
Here2Go
NAM Community Team
Slipping belt???
Just a guess.
Old May 24, 2024 | 04:46 AM
mrbean's Avatar
mrbean
Originally Posted by Here2Go
Slipping belt???
Just a guess.
+1
Sounds like a slipping belt.
With the reduction pulley, you need a belt that is shorter than stock. Make sure you have the right one installed.
Old May 24, 2024 | 08:25 AM
Here2Go's Avatar
Here2Go
NAM Community Team
I also have a few modest performance mods on my 04 R53 including a 15% SC reduction pulley.
If you come to determine that your belt might be slipping; here is
the belt the belt
I've been running with great results with my setup for the past 3years.
Best of luck.
Old May 24, 2024 | 10:09 AM
noodlesandsam's Avatar
noodlesandsam
Yes, if it has the stock belt, it will be too loose. I have had the same Alternator since 2005 ( 170K ). I run a Dinan 17% Pulley with the correct belt. It may also be a bad tensioner. Get a new belt, and new Tensioner, do them together.
Old May 24, 2024 | 03:37 PM
wizITup_'s Avatar
wizITup_
Thanks all, you rock. I actually just purchased the K060535 belt and the belt tool. I will get a new tensioner.
Speaking of tensioner - is the best/easiest way to remove the PS mount and raise the engine up 4 inches or so to access all the bolts holding it on?
Old May 25, 2024 | 04:31 AM
noodlesandsam
Have the battery load tested. On the e46, an 11 month old Die Hard Gold ( non agm ) died hard.
Old May 25, 2024 | 05:11 AM
noodlesandsam
khnitz
Oct 28, 2021 08:36 PM
rkj__
R60/R61 Stock Problems/Issues
Oct 15, 2019 07:11 AM
scottwitha5
Mar 23, 2019 04:26 PM
jimatvs
Jun 23, 2009 09:52 AM
owl
Apr 8, 2009 05:06 PM
