R50/53 Heated seats
Old May 14, 2024 | 09:53 AM
Jward4532's Avatar
Jward4532
Heated seats
Quick question. I currently have non-heated seats. If I get some heated seats and the stock controller can I simply swap them in? Plug n play?
2006 R53 MCS
Old May 14, 2024 | 10:15 AM
RudeJoe's Avatar
RudeJoe
No, you need the Retrofit wiring harness for adding heated seats. Mini sold a wiring kit at one time but discontinued it a couple years ago. I suppose you could create your own. Here's a link to the NLA kit:
https://www.ecstuning.com/b-genuine-...s/61120144084/
Old May 14, 2024 | 10:17 AM
megaDan's Avatar
megaDan
See Mini retrofit guide here
Coding is not required.
Obviously you need the seats, the wiring harness (I have an uncut harness available if you're in need), the switch, and a 20A fuse.
The linked PDF spells everything out. relatively clearly.
Old May 14, 2024 | 10:50 AM
Jward4532's Avatar
Jward4532
Thank you. I knew there was a guide on here but I couldn’t find it.
GregO
73
Feb 6, 2007 08:24 AM
nypepper
Apr 11, 2006 07:28 AM
jazper11
Feb 15, 2006 09:02 AM
