F55/F56 Low speed downshift clunk
Old May 2, 2024 | 01:23 PM
Oplix's Avatar
Oplix
My car started doing a clunking when downshifting to second at low speed. From general information I’ve looked at it could be anything from “u joint” to the throttle cable.
Anyone who had this issue please chime in. Trying to figure it out.
One other symptom is that when this happens on decel, it will make a smaller similar sound once I accelerate from a stop making me think it’s something which has too much play and then gets put back into its correct position after accelerating.
Car has 92k miles. 2016 MCS.
Old May 2, 2024 | 04:29 PM
Oplix's Avatar
Oplix
Also, I sort of hit a curb recently so it could be related to that. Perhaps wheel bearings?
Old May 3, 2024 | 04:42 AM
Stu-mon's Avatar
Stu-mon
better hope it's not a synchronizer
Old May 3, 2024 | 10:26 AM
WhatV8's Avatar
WhatV8
I would check your control arm bushings, could have torn one which would allow some metal to metal contact when you 'bump' the suspension with the downshift and acceleration. Hitting a curb could effect quite a few things. I would also check your engine mounts, as another thought.
Old May 12, 2024 | 12:09 PM
Oplix's Avatar
Oplix
great advice. i was thinking it could be an engine mount as well. havent had a chance to take the wheels off to look at everything but will soon when i do my rear brakes.
control arm bushings, end links, all that stuff could potentially have failed to some extent.
Old May 13, 2024 | 05:16 AM
johnnys2quick's Avatar
johnnys2quick
easy to check engine mount. visual inspect top left side on engine, sorta behind the head light.
Old May 13, 2024 | 08:53 AM
Oplix's Avatar
Oplix
it would probably be the lower one. i did replace the top mount about 20k miles ago and its still looking okay.
RllyDrvrIX
General Discussion
Jun 16, 2011 08:09 AM
ronn
Jul 7, 2006 11:34 AM
Storer
Jul 12, 2003 05:06 PM
fms
Mar 16, 2003 10:48 AM
