JCW What and where do I get gaskets ?
Old Apr 4, 2024 | 02:12 PM
MiniManAdam's Avatar
MiniManAdam
Community Builder
So this manifold I got cane with the thermal barrier spacers and it also has NO groves for o ring gaskets.
so here's my questions :
do I need 2x gaskets for the tbody and for the cylinder head to intake ? So do I need to put a gasket on each side if the thermal barriers ?? I'd assume so but....
AND where would I find a gaskets that would match ??? Or do I need to cut and make my own with a gasket sheet ? If so , what type material gaskets do you suggest ??.
Old Apr 4, 2024 | 04:41 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Sounds like a question for SpeedTech…. My guess would be to just use the gaskets it came with.
Old Apr 5, 2024 | 01:35 AM
MiniManAdam
Community Builder
didn't come with any unfortunately and the product has been discontinued for sometime now..
though heck , it's worth a try... thx you.
But I think I'm gonna buy gasket material just to have on hand just encase..
Also , is it safe for me to block off/delete passengers side pcv ? , id like a cleaner , better running ,flowing intake setup and I can have cel codes deleted out via adriancl. I found the block off cap for the valve cover but i dont wanna risk excessive crankcase pressure from building up.
other than the pcv I'd like to run all the other vacuum stuff as much as stock as possible.
BUT I will go to hardware store today and see if I can find a attachment that'd allow me to plumb in the pcv but i think that's gonna be luck if I do so I have mone of that so I need to plan and have backup plans then too.
Old Apr 5, 2024 | 05:55 AM
MiniManAdam
Community Builder
I actually got email back already from speedtech " it came with 2x gaskets , they are white and in a separate box. Please make sure they were included and didn't accidentally throw them away "
Are these phenolic spacers not spacers but actually thermal gaskets ? i cant imagine so but i tend to be wrong alot lately..
Old Apr 6, 2024 | 06:45 AM
MiniManAdam
Community Builder
Speedtech WAS rite...
I guess I just use the plastic things as the gaskets.
from what I found out : they are actually thermal gaskets which is same as a phenolic spacer. The thermal gaskets SHOULD seal without any other gaskets or rtv ect. They ARE also reusable which is a plus.
sooooo , when I install them , just to be safe because I'm **** , I WILL use copper gasket spray on both sides of the thermal gasket juuuuuuust to be safe. Back with my r53's i religiously used copper spray on the header gasket , intake manifold gasket and the supercharger horn gaskets. And never once did I EVER get a leak. I also do a good job prepping the surfaces too..
so wish me luck on the install guys !!! I will make a thread about my opinions on this manifold too.
Oh Six Mini
Sep 4, 2019 05:53 AM
cpmetz
Factory JCW Talk (2009+)
Mar 23, 2019 03:15 PM
FlzRider
May 19, 2018 04:54 AM
The Angry Pumkin
May 18, 2013 09:07 PM
Jonauto
Jul 28, 2004 06:42 PM
