Mini Connected : need an fsc code
Old Mar 15, 2024 | 03:43 PM
supercyprien's Avatar
supercyprien
I own a Pre-LCI R56 Mini. I recently retrofited champ2 nav unit (it works with an emulator).
The unit I bought has not voice control and Mini connected. Could someone generate me fsc codes to be able to retrofit that in my car ?
I can't ask BMW/mini since the VIN on my champ unit is not the same as my car.... and Mini does not sell these fsc codes for my car since it is a pre-LCI model.
I have some fsc files for that but not with the same VIN as the unit I use.
If I change the VIN on the champ unit then I put FSC files to activate these options, is there any risk of destroying nav fsc that are recorded and accepted ?
Thank you for your help !
Old Nov 25, 2024 | 12:28 AM
24_alex's Avatar
24_alex
Hi, I'm planning to do the same retrofit on a R56 LCI, did you manage to make everything work? And if yes could you explain briefly how?
Thank you
Old Nov 25, 2024 | 02:43 PM
supercyprien
Thank you
I had to buy an emulator to make the radio/gps unit work properly.
Old Nov 25, 2024 | 02:45 PM
supercyprien
Thank you
Old Nov 26, 2024 | 12:32 AM
24_alex's Avatar
24_alex
Do you have a link for the emulator you bought?
Is everything working fine with the emulator? I've seen on other posts that some emulators mess up with some Mini Connected functions and PDC, is that your case?
Old Nov 26, 2024 | 09:18 AM
supercyprien
I had also read this, but with the emulator that I finally got the PDC works well. I don’t have the mini connected, but I think some features will not be accessible because the VIN of the champ2 will not be that of the car.
I bought an emulator here : https://emtronika.com/en/
Ask them which one is for the Mini R56.
jamestoogood
340
Dec 16, 2024 07:16 AM
kfmuller
Navigation and Audio
Mar 11, 2024 09:04 AM
supercyprien
Electrical
Oct 23, 2023 12:43 PM
josesilvaminir56
Oct 12, 2023 01:28 AM
marinabrian
Feb 28, 2021 11:40 PM
