R50/53 Boost and vacuum question.
Old Feb 23, 2024 | 12:36 PM
Green04minis's Avatar
Green04minis
So I picked up a r53 s. With 123k on it my boost is maxing out around 9.5 and vacuum off throttle is in the 18 range is this normal or am I missing something.. I did the bypass valve and feel like I lost some low end power. I know I need to get all new hose clamps but all the hoses are tight as anything on them.. any help would be appreciated new to the mini community.
Old Feb 23, 2024 | 02:25 PM
Here2Go's Avatar
Here2Go
NAM Community Team
Do you have any mods - i.e: Supercharger reduction pulley (-15, -17), 2% crank pulley, Cold air intake, 380 cc (+) injectors etc?
-18 hg @ idle sounds about right. 9.5 @ WOT does not.
You may want to do a simple smoke test for any potential vacuum leaks as well as a compression test.
A leak down test maybe a consideration as well.
Hopefully one or more of the more seasoned/experienced contributors can offer their expert opinion(s).
Old Feb 23, 2024 | 04:33 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
At WOT, even the slightest amount unmetered air can cause boost to drop off. If you haven't already, remove the intercooler, check the intercooler boots and the vacuum lines under there for cracking and good connection. With everything out back together, an easy test is to judiciously spray starting ether around suspicious leak points. A rise in rpm points to a source of the leak.
Old Feb 23, 2024 | 04:37 PM
Green04minis
No mods . She is bone stock of the moment. I did adjust the bypass valve today. I did not see any busted lines or anything any where. So I should just get a can of starting fluid and start spraying then ?
Old Feb 23, 2024 | 04:38 PM
Green04minis
Is there any point u adjust the bypass valve to much and can lose boost?
Old Feb 24, 2024 | 01:13 PM
Green04minis
Ok so sprayed the whole motor pretty much with starting fluid and I got no change in rpms or anything... how every I did end up throw a evap code witch I never had before... any info would be appreciated or help.. thought would have had more help by now.. this is screen shots of still at idle
MiniManAdam
Apr 3, 2022 08:33 PM
Silver253
Oct 8, 2010 12:30 PM
EDM
Jul 27, 2007 07:24 AM
sanddan
Oct 26, 2006 01:45 PM
LoryIII
Apr 20, 2004 05:32 PM
