Hi folks - I have some Bilstein PSS10's that will lower my r53 about 1.5 inches. I'm using IE fixed camber plates up front, but curious if I need adjustable rear control arms as well? Now's the time to do it as I have the rear subframe pulled, but it's yet another thing to spend money on!
And while I have you, I've got a whiteline sway bar ready to go but should I consider other bushing upgrades that won't be a complete PIA? I don't want to compromise ride quality as it's a daily driver, but interested in thoughts.
Appreciate the insight fellas!!
Dang, that's a deal compared to elsewhere and they have good reviews. I know I could go Hotchkiss for $300 or so but I have to draw the line at some point; I'll give them a go - seems a necessity to not chew up my tires, as I continue to dig.
I have the Hotchkiss on my Clubman, and really, overkill for street use. Plus, the bushings are poly, so regular greasing is a requirement. The rubber bushings in the control arms are so thin, its almost like they aren't really there.
I have installed the (near) identical rear control arms as njaremka linked to. Mine are the Dorman brand, aluminum ones, I bought for the same amount of $$ back in 2022.
They worked great as for fine tuning/adjusting my rear camber. Super happy that I made the upgrade at a bargain $$. I also installed an Alta 23mm rear swaybar w/powerflex RSBushings at the time.
As for Godspeed adjustables - there's a reasonably good price on a pair of pre-owned in the marketplace right now. If you are s inclined.
I've done spherical bearings on suspension parts before. NO WAY would I recommend them for anything that will see street / daily driver use. Spherical bearings are nice for feedback, but terrible for noises and durability.
Thanks all, I went Mavotech - last ones in stock at that price and less than half of amazon, ebay, etc. Sometimes you get lucky - Njaremka, you're my hero of the day.
Good to know!
I'm glad I made the right choice not knowing any better.
I should add that: I had purchased my Dorman adjustable lower control arms from Amazon (circa 2022) for about $90 for the pair.
What I didn't know / AND what the Amazon seller didn't realize, was that there are 2wo different versions of the SAME design. The primary difference is that: one model # is steel @ $80/pair and the other model # is aluminum @ $300/pair.
There in lies the confusion....I received the aluminum ones for $80 + tx/sh. They had realized their error and have since priced the aluminum version @ 135/ea OR $400+ /pair.
Ignorance is bliss.
...at least for me
Reason: bad grammer
By the way, I find it mildly curious that you’re lowering the car 1.5” but are also simultaneously concerned about ride quality.
It's the nature of the coilovers - they adjust from 30-50cm reduction in ride height, and I'll go closer to 30. I did a lot of research and, while of course they firm up the ride, when dialed in more for comfort than competition they seem a solid choice. We'll see...
Thanks for the lead on the "cage nuts", just bought a pair to replace. Great site for parts diagrams, btw.
I'll be waiting for a review of your PSS10 setup once you've got it dialed in. I have the B14 PSS coilovers on my R53. I really wanted the PSS10 but could not justify the price.
Agreed - they are more that the bargain price I paid for the whole car and unsure how there's a market left for those kinds of prices on R53 parts. I grabbed an almost new set on the marketplace for half that, otherwise no way.
I'll let you know how they ride - seems a long way off with the my car almost completely dissassembled!
