R56 How many wires on your upstream O2 sensor?
Old Feb 15, 2024 | 04:02 PM
mkov608's Avatar
mkov608
If you look at the wiring diagram and the engine wiring harness, you'll notice there are 6 wires for the Upstream O2 sensor (wideband) on the N series engines.
However, the Bosch and NTK sensors have 6 pins but only 5 wires. Does anybody out there have a genuine MINI O2 sensor that could report how many wires on coming out of their sensor? I'm wondering if the Bosch and NTK sensor are sharing a ground or power inside the sensor connector.
Here's a pic from the wiring diagram.
Old Feb 15, 2024 | 07:36 PM
mkov608's Avatar
mkov608
Well, I think I figured it out. It's ok to have a 5 wire sensor plugged into a 6 wire harness. "To save wires, the Vs (sense) and the Ip (pump) cells are connected together - they share a common reaction surface anyway, so this isn't a problem."
https://wbo2.com/lsu/lsuworks.htm
I've updated the MINI schematic to go along with the above theory of operation link above.
Next step it to get my multi-meter out and check to make sure I got it right.
Old Feb 21, 2024 | 02:04 PM
mkov608's Avatar
mkov608
Ah haaaa!
Go to the 30 minute mark in the video.
Russter500
Oct 19, 2021 07:35 AM
Gerard778
May 6, 2021 10:13 AM
Kennedy
Feb 5, 2014 11:42 AM
Frodo
Aug 9, 2006 08:19 AM
