Drivetrain More HP from improved grounding?
Old Jan 29, 2005 | 08:42 AM
62Lincoln's Avatar
62Lincoln
Yes, I'm skeptical, but I ran across this on another s/c forum, and apparently magazines such as Import Tuner have tested and verified the gains. I'm still skeptical, but hopefully those of you in the know can fill in the blanks. Here's the site for the manufacturer: http://www.speedoptions.com/eh/default.htm
Old Jan 29, 2005 | 09:00 AM
sright's Avatar
sright
NO data to back up the claims . Definately helps with the build up of static charges which would help with radio clarity and would offer some safety benfit.
Old Jan 29, 2005 | 09:03 AM
10851CS's Avatar
10851CS
A local person was selling this "system" of grounding with the idea it worked so he wanted a MINI to put it on to show. I went to his place, poped the bonnett and he looked and said he didn't see anywhere to ground it that wasn't already done. He decided not to make it for the MINI.
Earl
Old Jan 29, 2005 | 09:10 AM
flyboy2160's Avatar
flyboy2160
total b.s. to scam the technically illiterate. may as well get a tornado gizmo while you're at it......
i suspect the testing of the "imrovements" is like that claimed from some spark plugs and from some ignition gizmos. if the components, especially spark plugs, are old (or here, you have a bad ground), you can show improvements by just replacing the old part with a new one of the identical part. so if you replace the old worn one with your gizmo and show improvement, well, then, yessiree, bob, we have the engine elixir right here......
Old Jan 29, 2005 | 10:42 AM
62Lincoln's Avatar
62Lincoln
I went digging to try to find the article in Import Tuner that was mentioned at the other forum. Couldn't find the article, but found several references to the product on other tests the magazine has performed. Ended up going to the website of the company, and here's what I found (with dynos): http://www.sunautomobile.com/
I'm STILL skeptical, but this tweaks my interest.
Old Jan 29, 2005 | 06:49 PM
flyboy2160's Avatar
flyboy2160
for any of these devices, the proper proof of benefits is not only a test, but also a rational, scientific explanation of the the physical phenomenon involved.
Old May 19, 2005 | 10:34 AM
CAMOTOY's Avatar
CAMOTOY
yea, back from the dead i know :D
I did end up making these kits after a friend talked about getting shocked all the time getting out of her car. With the kit, it seemed to diminish some. As for making the car faster, better, who knows. I do know that most people that have bought it, have liked it.
Shane
Earl
Old May 19, 2005 | 10:51 AM
kaelaria's Avatar
kaelaria
Magazines are worthless. Any advertiser can buy an editorial and results. I know first hand
Old May 19, 2005 | 11:01 AM
SumWon's Avatar
SumWon
Now that would be a worth while product. I hate getting zapped everytime I get of the MINI.
Old May 19, 2005 | 11:19 AM
warchieft2k's Avatar
warchieft2k
i have to say.. it does work on some cars like WRXs b/c their factory ground set up is a good as none.
so when you ground the car you get improved the voltage power and that will help your improve your spark at high RPM... or "more HP"
now minis are well grounded from the factory... you can test it yourself, all you do is get a voltimeter and test different parts of the engine bay.
my advice... dont waste your time, unless after the testing you find that the areas you tested are not well grounded.
Carlos
Old May 19, 2005 | 12:57 PM
KevinR's Avatar
KevinR
These things are discussed fairly routinely on the VW/Audi 1.8T forums. Generally small skirmishes break out between the kool-aid drinkers and the nay-sayers with no proof of performance/lack of performance to be shown from either camp.
Stopping the shock from getting out of the car would be nice, though I only notice it in the cold months.
Old May 19, 2005 | 06:04 PM
ScottinBend's Avatar
ScottinBend
Getting shocked while getting out of the car comes from the clothes you are wearing. Has nothing to do with the cars grounding.
Old May 19, 2005 | 06:19 PM
Pendergast's Avatar
Pendergast
Agree with ScottinBend. This device would have no effect on static charges, the shock from which comes from a difference in potential between you and the car. Either you or the car acts as a capacitor holding the charge until enought voltage exists to jump the gap, measured in thousands of volts.
Only a poor connection between the car and battery would be helped by this device.
Bilbo-Baggins's Avatar
Bilbo-Baggins
You would be better served by the installation of a grounding strap the goes from a good ground on the frame and extends down to touch the earth beneath the vehicle. That would disapate the static spark generated between the clothing and the car.
Have you ever noticed little antenna on the ground as you approach a toll booth? They are there so that you don't shock the attendant while handing them the toll. Same idea.
Old May 19, 2005 | 06:42 PM
gmcdonnell's Avatar
gmcdonnell
...boy, I'm sure glad that never happens on this forum...
Old May 19, 2005 | 07:29 PM
CAMOTOY's Avatar
CAMOTOY
yea, no kidding :D
Old May 19, 2005 | 08:18 PM
KevinR's Avatar
KevinR
Don't think I can drive around naked...
Old May 20, 2005 | 07:32 AM
SumWon's Avatar
SumWon
That may be the case, I just notice that the MINI is the only car that I have owned (or still own) that I get shocked nearly every time I get out of it (and no, I don't wear the same clothes all the time ).
Old May 20, 2005 | 07:39 AM
Rally@StanceDesign's Avatar
Rally@StanceDesign
SJ-R50
Oct 28, 2015 08:39 AM
Suspension Products
Oct 1, 2015 11:53 AM
Suspension Products
Oct 1, 2015 11:14 AM
Emnotek
Sep 29, 2015 07:37 AM
