R56 Brake Pad Front Worn sensor get loose from driving on gravel road?
Old Jan 7, 2024 | 02:57 PM
theateist's Avatar
theateist
I replaced the brakes+rotors+sensors 2 months ago. Today I got brake light on. The OBD2 tool showed me "Brake Pad Front Worn 5E5C" code. In fact, the day before I was driving on a gravel road. Could the sensor become loose or something due to the shaking when driving on a gravel road? Or is this nonsense and perhaps the sensor is faulty?
Old Jan 8, 2024 | 11:13 AM
Could have wiggles loose or popped out of place and hit the rotor. Biggest thing i have seen is the plug connection comes loose where it plugs into the main harness, you have to snap them in on the long plug all the way down.
Old Jan 8, 2024 | 12:15 PM
theateist's Avatar
theateist
  • I found
    tutorial and seems I can try checking or eventaully replacing the sensor myself. Assuming the cable is still intact on both ends, should I just try disconnecting and re-connecting it back?
  • Also, I have new REAR brake pad sensor. Can I use it to replace the front one? They visually seem identical, but I'd like to ask here just in case.
GoThingNC
Mar 27, 2017 06:38 AM
pkillur
Tires, Wheels, & Brakes
Oct 1, 2015 03:59 AM
artiechas
Jun 25, 2010 04:09 AM
sjustorm15
May 31, 2010 05:02 PM
AllanS
Dec 20, 2009 04:47 PM
