R50/53 Need Damos for R53 ECU (EMS 2000)
Hello,
I want to remap my ECU after changing my intercooler.
I have the project to add new injectors, i need some help to choose the right one.
This is my daily car, so i want to have more power but keeping a good fuel consumption.
My change are 15% Pulley, msd coil and the airtec intercooler, KN filter in the oem box (dynamic admission- REDLINE Box)
Thanks for your feedbacks
Kind regards
Kind regards
https://www.fcpeuro.com/products/aud...tro-0280156063
im running these, I did swap all the o rings for oem mini ones before installing them. No need for pig tails, plug and play. These are 380’s and I didn’t need a tune but I had AdrianCl tune it. He is a member of the forum and can be found via Facebook @Nastase Adrian, he has tuned a lot of r53’s, r50’s, and can do the stupid n14. Totally worth it.
Contact Adrian Nastase (adriancl on this forum) for tuning information. Also consider switching your R53 to the facelift MS5150 ECU. It has more tuning capability than the EMS2000. Adrian provided a tuned MS5150 ECU for my R53 but also tuned my EMS2000 ECU. The performance increase by using the MS5150 is amazing -- much more responsive than the tuned EMS2000. This will be one of the best modifications you can make to your Mini.
Hello,
Thanks for your feedback, i will try to talk with Adrian...About putting the stock intercooler....forget it because it cost me a lot more than 450 dollars and i got good result with it..
The car breathes better and is much smoother compared to the stock intercooler....
When i go to the Technical inspection i put the stock back and i feel the difference directly
For the msd I'm not convinced but I bought it, I'm not going to throw it away
Have a good days guys
