R56 Automatic trans leak at axle seal?
Old Jan 4, 2024 | 05:57 PM
Lex2008's Avatar
Lex2008
If the automatic trans fluid is red, why does the leak not look red? hmmmmm
Old Jan 5, 2024 | 06:18 AM
RockC's Avatar
RockC
Leak not bad enough to produce enough fluid to show any color.
But your suspicion that seal may not be the source of the leak has merit.
For diagnosing leaks I've used brake cleaner (in an aerosol can) to spray down the areas showing any fluid leak sign and this includes any areas above/around the areas appearing directly affected. Then drive the car some and check very carefully for leak sign from some place above or ahead of where the leak is suspected of being located. And of course the area in pictured.
You may have to drive the car several times before you see where the leak originates because, as I touched upon above, the leak doesn't look to be that bad.
Old Jan 5, 2024 | 12:31 PM
mkov608's Avatar
mkov608
How many miles are on your transmission fluid? New fluid is red; old fluid .... I don't even see enough fluid to form a drop.
Old Jan 5, 2024 | 12:41 PM
Lex2008's Avatar
Lex2008
maybe like 30k miles on that fluid...its due for a change.
Old Jan 5, 2024 | 12:44 PM
Lex2008's Avatar
Lex2008
MIGHT be from the PCV connection under the intake manifold but its not directly under the shaft seal, but that would explain the color of the stain.
Old Jan 17, 2024 | 08:11 AM
Lex2008's Avatar
Lex2008
Anyone have experience with Corteco versus OEM brand? FCP Euro claims Corteco is OEM supplier but the colors are different.
ECS Tuning shows them as different colors
Old Jan 17, 2024 | 08:37 AM
mkov608's Avatar
mkov608
Yes, I've used them ... no issues.
Old Jan 17, 2024 | 08:41 AM
Lex2008's Avatar
Lex2008
Did you also change the small rubber o-ring?
#12 in the parts explosion.
Morphius
11
Sep 17, 2020 12:07 AM
tbearmini
Jan 12, 2014 03:51 PM
KittyMini
Oct 28, 2009 11:03 AM
2006Chili
Aug 28, 2009 03:56 PM
ofioliti
Apr 21, 2006 01:40 PM
