R56 Important Electrical Grounds (Earths) to maintain on R56 m
Old Jan 2, 2024 | 07:28 AM
Lex2008's Avatar
Lex2008
A bad electrical ground (earth) as can cause all manner of CELs so as your car ages make sure and check these. Pull them, sand them down and put them back on with a dab of low or medium strength Loctite so they never come loose.
From the Bentley manual:
The one's I found in the engine bay, the ones most likely to rust, are:
In front of battery to engine a braided strap. Need to remove the headlight to access the other end. Mine looked ok....but showing age.
On the front valve cover for the spark plug coils.
3 of them on the driver's side in front of firewall...you need to remove the ECM and the fuse box needs to be unfastened so you can pull it out of the way. Its 4 10mm and one 8 I believe. Very easy.
Just behind the motor/trans mount for the 3 brown wires.
Also here is a TSB on a bad electrical ground related to Airbag, ABS and DSC; electric windows or other systems are not working; and there is no communication with various control modules. This might correspond to the two right next to each other in the pic above but I'm snot sure. The drawing below makes it look like they are under the wheel well cover.
November 2009
Technical Service
This Service Information bulletin supersedes SI M61 05 07 dated September 2007.
[NEW] designates changes to this revision
SUBJECT
Bad
Ground Causes Various Electrical Problems
MODEL
[NEW] R55 (Cooper Clubman, Cooper S Clubman)
R56 (Cooper, Cooper S)
[NEW] R57 (Cooper Convertible, Cooper S Convertible)
SITUATION
Various warning lights are illuminated, e.g., Airbag, ABS and DSC; electric windows or other systems are not working; and there is no communication with various control modules.
CAUSE
Ground points X13004 and/or X4 are loose (not connected correctly).
Open In New Tab Zoom/Print
PROCEDURE
WARRANTY INFORMATION
Covered under the terms of the MINI New Vehicle Limited Warranty.
Please refer to the latest KSD for all applicable labor operations and allowances.
If the appropriate labor operation is not contained in KSD, then a work time labor operation should be used.
Defect Code Refer to KSD for the code that best represents the problem concerned.
If you know of any others in the engine bay let me know!
Dirtiegirtie
R57 :: Cabrio Talk (2009+)
12
Jul 21, 2023 12:57 PM
MiniToBe
R61 :: Paceman Talk
29
Dec 23, 2019 09:26 AM
NascarGuy
Dec 28, 2015 10:23 AM
ELF
Oct 21, 2010 06:50 PM
Helix13mini
Feb 1, 2006 04:24 PM
