Do I have to replace oil along with intake solenoid?
Old Dec 18, 2023 | 11:16 AM
theateist's Avatar
theateist
I have MINI Cooper S 2009 R56.
I changed the oil a year ago, although I have driven about 1k miles in the last year. I guess I need to change the oil, right? I also need to replace the VANOS solenoid. I plan to replace the solenoid myself. Can I replace the solenoid and then go to the shop for an oil change, or do I HAVE to change the oil before replacing the solenoid, or does it not matter?
Old Dec 18, 2023 | 12:08 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
The amount of oil loss from changing the VANOS solenoid will be a few drops, if that. You can change it out without having to drain and fill the oil.
Old Dec 18, 2023 | 12:17 PM
theateist's Avatar
theateist
I don't worry about losing oil. It's just that my logic tells me that since there is old oil, it might clog or do something else to the solenoid before I can change the oil. Does my way of thinking make no sense?
Also, do you know what "Not Present" mean in the image above?
Old Dec 18, 2023 | 12:19 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
With only 1000 miles on the oil, I wouldn't worry about it
Old Dec 18, 2023 | 03:25 PM
theateist's Avatar
theateist
But, let's say I do need to change the oil. I was planning to replace the solenoid in the morning and then drive to a guy I know (50mile) to change the oil. Should I first change the oil and then replace the solenoid or can I replace the solenoid and then drive 50 miles to change the oil? I just don't know if driving on "bad" oil for 50 miles can ruin or damage the solenoid in long run?
Old Dec 19, 2023 | 05:38 AM
RockC's Avatar
RockC
If the oil was bad enough at 1K miles to put the solenoid at risk I'd fear for the bearings, valve train hardware, etc.
An argument could be made the 1 year old oil could be due for a change. Not for any real concern about the solenoid but for everything that in some way depends upon the oil. While 1K miles is not a lot of miles in a year's time it suggests the car was used for short trips. If so these short trips tend to contaminate oil -- water and fuel -- and the short trips do not get the engine and oil hot enough to remove these contaminates. An oil change on time addresses this.
To cover all bases change the oil/filter *before* you replace the solenoid. But you must be extra extra careful you don't let any dirt or debris into the engine when replacing the solenoid. This caution applies regardless of if you change the oil before or after the solenoid R&R.
niquemarshall
Aug 4, 2011 03:15 PM
Horatio
Aug 19, 2008 08:06 PM
npalao
Jun 11, 2008 05:38 AM
Ex-Pat Brit
Dec 15, 2007 06:54 AM
S Curvz
Off-Topic :: Autos
Nov 8, 2006 06:52 AM
