R56 DME: Protection against tampering Code 00375c
Old Nov 13, 2023 | 05:26 PM
Wrightbenz's Avatar
Wrightbenz
Hi my 2011 mini S has a code I can’t clear. The code is 00375c anti tampering. I believe this may be from a tune someone did before I purchased the car. Car runs fine with the code but it caused the check engine light to come on.
Anyone have any advice on sorting this out ?
Old Nov 14, 2023 | 01:34 AM
Vanski's Avatar
Vanski
@Wrightbenz ,
If that code can't be cleared, you'll need to have your DME either have it relearned or be reprogrammed by a dealership since the driver modified for whatever he did outside the parameter as per manufacturer rules.
Old Nov 14, 2023 | 05:36 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
www.bmwfault.codes
Here is your service plan for that code:
- Replace the DME if the fault is permanently present or the fault occurrence count is higher than 3.
Sounds like a replacement DME is possibly in your future.
Old Nov 14, 2023 | 04:48 PM
Wrightbenz's Avatar
Wrightbenz
Originally Posted by njaremka
www.bmwfault.codes
Maybe. Car works fine though just have the check light. I’m sure it can be reflashed if someone knows what they are doing.
changing just the DME isn’t really an option is it ? Don’t they have to be paired with the ews module ?
Old Nov 15, 2023 | 05:10 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Maybe try talking to @Lou@Prototype-R . He does flash tuning, so maybe he could help out, or at the least tell you what you'll need to do. The only other alternative would be heading to the dealer, but I feel they would lean on the replacement path.
OK_R56SMT
Sep 21, 2023 08:32 AM
kandpand
Aug 4, 2021 10:10 AM
mrcolby321@yahoo.com
Oct 12, 2019 02:52 PM
Andrew Park
Feb 13, 2019 08:43 PM
