R56 Oil drain plug leak
Old Nov 12, 2023 | 07:18 AM
reddrampage's Avatar
reddrampage
Oil drain plug leak
I changed my oil and used the new gasket with the filter. after 2-3 days the plug started leaking a lot! I retorqued and it continued to leak, replaced the cooper gasket and still a minor leak.
i have a new plug and gasket coming in but im not hopeful. Any ideas?
Old Nov 12, 2023 | 11:10 AM
Yoshimura 1's Avatar
Yoshimura 1
Did you over torque that .........where is the leak from......the oil filter housing or oil pan?
Old Nov 12, 2023 | 11:12 AM
Yoshimura 1
I never torqued those components......
Old Nov 13, 2023 | 02:16 AM
Vanski's Avatar
Vanski
@reddrampage ,
If in fact the oil is leaking from the drain plug, then you'll need to re-tap it(re-threader). You may have stripped the oil drain plug threads. Make sure there is no wetness on the oil pan just above the drain plug. If you're not sure, you'll need to wipe it clean and drive it.
Old Nov 15, 2023 | 07:16 PM
Gubi's Avatar
Gubi
Well, not necessarily: the copper washer makes the oil seal, not the threads. As long as you can torque it to spec (30 Nm or 22 ft-lb: use a torque wrench) then the threads are fine.
What I learned the hard way was that you really need to use a fresh Mini OEM copper washer on the R56 to get it to seal. The Mini washer has a curved profile and for some reason it needs that to seal right: the one time I tried with a standard square copper washer from the auto parts store it leaked. Put a Mini washer on and retorqued to spec and no more leaks. No idea why this is, I've changed a lot of oil and I've never had another car be this picky about the sealing washer, but that's my experience.
If you still have the old washer you can anneal (soften) it and re-use it. Heat it with a propane torch until it glows a cherry red, drop it in water to cool it, and you're good to go.
Old Dec 12, 2023 | 01:47 PM
HausMD's Avatar
HausMD
Alliance Member
Veteran: Army
I had the same issue and it’s because I tried to use a standard flat washer compared to the oval design that the car is designed for. Here’s the P/N for oval washer. I always order 10 at a time along wi the new oil filters.
#11137546275
Old Dec 13, 2023 | 06:05 AM
Yep you need the what we call a tube washer.
https://www.ecstuning.com/Search/Sit...h/11137546275/
Old Dec 13, 2023 | 08:36 AM
yyj3869's Avatar
yyj3869
yeah it's washer for 100% sure. if you purchased aftermarket oil filter with washer then it happens. I've experienced that before.. you should buy that washer
Old Feb 5, 2024 | 03:00 PM
reddrampage
sorry I never replied to anyone, I forgot I even made the post haha. Yes you were all correct I ordered an OEM ring and plug and it worked right away, thank you all
r53-06m6
Feb 24, 2025 02:18 PM
Red Robin
Jan 20, 2019 07:11 AM
romero.riche
Nov 24, 2017 09:59 AM
YearOneMCS
Mar 29, 2012 06:37 PM
jc8899311
Jun 27, 2009 07:31 AM
