Rear hatch latch issues
Old Nov 1, 2023 | 08:29 AM
tag1260's Avatar
tag1260
Having an issue with my R56 rear hatch latch. Seems it will only latch if I hit the button on my key fob before closing it. If I don't it will not latch. It stays latched if I hit the fob and it opens fine with the handle. Anyone else run into this? Any advise? .
Before I discovered how to get it to latch I already replaced the latch itself and that wasn't it. Thanks
Old Nov 2, 2023 | 04:27 AM
RockC's Avatar
RockC
Reads like there is a hatch latch switch/sensor problem. The latch releases and the hatch is opened but the latch assumes the latched position after the hatch is opened.
'course, I offer the above without the benefit of having a wiring diagram to confirm there is a hatch switch/sensor. But I think there is because if the hatch is not closed fully there is (at least in my experience with 2018, 2020, 2023 MINIs) a warning of an open hatch on the dash. This implies there is a sensor.
I'm reluctant to mention this as I really do not like to disconnect the battery unless absolutely necessary but you might consider a careful/by the book battery disconnect and long enough for the car's electrical system to lose all residual power. Then a just as careful/by the book reconnect of the battery.
IOWs you give the car's electrical system a power reset...
MrFunk
Feb 21, 2018 02:49 PM
a1machinista1
Jan 10, 2018 01:16 PM
OneTraveler
Jun 3, 2013 11:27 AM
lexifan
Sep 16, 2009 10:35 AM
SkiGirl
Jun 27, 2009 09:30 AM
