R50/53 My door won't shut
Old Jan 27, 2005 | 07:56 PM
airmini's Avatar
airmini
My door won't shut
Well after reading many posts about stuck windows, my MINI window finally stuck. I was on the highway for about 2 hours in -6F weather and when I arrived home the window did not drop when the door opened. So when I shut the door it would not shut but bounced back open. There was no snow during my trip just cold. I thought the door handle might be frozen so tried to using a hair drying to warm the handle but the window still will not drop. Window works fine up and down from inside the car. Lucky the MINI is in the garage. I had to roll the window down a couple inches to shut the door. Anyone else have this problem?
Could be a problem in the morning if I have to leave the driver window slightly open at work, while it's snowing.
Old Jan 27, 2005 | 08:20 PM
lotsie's Avatar
lotsie
The only time this has happened to me was because the window was not up all the way,by an 1/8 of an inch.I think if you hold the toggle up for 5 seconds or so,the window brains reset.Give it a try.
Old Jan 27, 2005 | 08:26 PM
airmini's Avatar
airmini
Door won't shut
Tried the 5 second window up and no luck. It's still -16C (-4F) in the garage. Maybe it's just the cold. Thanks anyway.
Old Jan 28, 2005 | 01:32 AM
mikeoconnor1's Avatar
mikeoconnor1
I had and still have problems with my door when it is cold. Last year, I had to get towed to the dealer for replacement of the door handle. The handle also controls the interior lighting so my lights stayed on all night. They would fade and then come back on while the window was doing this up/down dance.
I also saw a post a while back regarding the springs on the outside handle being weak. The person replaced them and it solved a lot of his issues.
Oh, and my car did the same thing as yours initially. It would work fine with the window down a smidge. Just when it tried to do that dip would it fail. Be prepared, your handle may be ready to fail completely like mine did.
I still have problems with the handle freezing and it being difficult to open the door. As a result I usually take my wife's car to work. (We work different shifts). There are a lot of minor inconveniences I can live with, but this is not one of them. It has me seriously reconsidering my next car purchase. I really wanted a convertible, but with this lingering problem, who knows?
Old Jan 28, 2005 | 02:55 PM
airmini's Avatar
airmini
Windows working
Hey lot15 you were very close. Called the MINI tech and he advised to open the window all the way then close it and hold the window switch up for 1 to 2 minutes to reset the system. It worked. Saved a trip to the dealer.
Old Jan 28, 2005 | 03:40 PM
lotsie's Avatar
lotsie
Seems like a long time to hold in the up position,but hey glad it fixed your problemI guess if it gets out of sync.it takes some time to figure out what is wrong
dube53
R58 :: Coupé Talk (2012+)
Sep 11, 2015 09:30 AM
David Eric Rosenberg
R57 :: Cabrio Talk (2009+)
Sep 10, 2015 12:34 PM
Filmy
Sep 7, 2015 08:27 PM
Sep 3, 2015 10:45 AM
Southern Marylander
Sep 3, 2015 05:46 AM
