R50/53 R53 steel coolant lines help
Old Sep 25, 2023 | 03:35 AM
R53best's Avatar
R53best
Hi guys, wondering if anyone knows how to take off these coolant hoses going to the heat exchanger behind the engine, mine is chocka full with peanut butter. Or anyone have any idea how to clean this? Put a new heat exchanger in and flushed coolant, no oil or signs of oil so assuming the blockage is only on the steel lines?
Old Sep 25, 2023 | 06:56 AM
Daftlad's Avatar
Daftlad
https://www.realoem.com/bmw/enUS/sho...diagId=17_0237
Diagram at link above indicates it's one assembly held on with two bolts, connected as shown at one end to the oil cooler and the rest of the heater / cooling hose network at the other. If your bolts are badly corroded / frozen would consider leaving it in place (assuming the pipes are not leaking) and gently flushing it from both ends and using a long bottle brush to clean out the peanut butter as you say. Failing that, replacement:
https://www.outmotoring.com/_search....03&categoryid=
Old Sep 25, 2023 | 10:06 AM
R53best's Avatar
R53best
Hey, any idea how to access the bolt for it? I cant seem to reach the one near the thermostat side? Do u get at it from the top or bottom?
Old Sep 25, 2023 | 03:00 PM
Daftlad's Avatar
Daftlad
Would go through the right wheel well for that end and probably from above after removing the air box and ECU (remember to disconnect the negative battery cable first) and possibly from below, not sure.
Old Sep 25, 2023 | 03:43 PM
Onizukachan's Avatar
Onizukachan
You are talking about the cooling loop? The bolt is from the top. 10mm iirc.
or just unhook form heat exchanger, put some simpl3 green in it and hook a hose up to it and flush it?
Old Sep 26, 2023 | 03:48 AM
Daftlad's Avatar
Daftlad
two bolts from the top, long way down, under the heat shields. Still have to come in from the left side to disconnect those hoses and R/R it. Would think flushing would best be accomplished with left side ends open anyway but maybe not. But if you're at that point, might as well just remove it altogether before cleaning / replacement. Then 'while you're in there' R/R the thermostat, housing, temperature sensor, and Rube Goldberg labrynth of 22 tiny coolant / heater hoses, plastic connectors, and skin-shredding factory clamps stuffed in behind the engine...it never ends...
peerware
Aug 6, 2020 08:10 AM
FatherSonRebuilds
Jun 29, 2020 08:32 AM
scatpack
Sep 17, 2012 09:52 AM
danthemanohhyea
Jul 23, 2012 11:03 AM
gizzer777
Nov 29, 2006 11:10 AM
