Weird smell when accelerating
Old Sep 23, 2023 | 12:45 PM
Onunezp201's Avatar
Onunezp201
Hi guys, I am new to the mini world. I recently got an 06 MCS. Whenever I accelerate moderately hard for 20-30 seconds. I get this smell, like rotten eggs or similar (inside the cab). I know that I need to change SC oil to service it but it is not easy task. Especially in my country so I will have to tackle that myself. But I wanted to know if a bad cat would send out that smell or if you had experienced something thing like this. Thank you.
Old Sep 23, 2023 | 04:41 PM
cooper48's Avatar
cooper48
Check your crank pulley. It has a rubber core that deteriorates over time. When that happens the outer pulley doesn't spin as fast as the core. The two parts rubbing against each other creates a burning smell. Easiest access is thru the passenger-side wheel well once the fender liner is removed.
Old Sep 23, 2023 | 07:18 PM
Here2Go's Avatar
Here2Go
NAM Community Team
+1 = undoubtedly the OEM crank pulley.
I've been through at least 4 (OEM/factory) in my Mini since 2004.
I'd suggest replacing it with a PRW (fluid filled) or an ATI super damper.
They may cost more (unless gawd forbid - you go to the dealer for another OEM/factory) but piece of mind for miles upon miles, years upon years down the road.
I would avoid replacing the crank pulley with another same OEM/factory unless you don't mind having to replace it more than every so often...Or worse - (perhaps) causing catastrophic damage to your motor when they finally do will fail.
Old Oct 2, 2023 | 06:15 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Inspect your harmonic damper before changing it out but you are correct that rotten egg smell is an indication of a fouled catalytic converter.
Old Oct 3, 2023 | 10:26 AM
Here2Go's Avatar
Here2Go
NAM Community Team
Good to know.
I've never experienced it myself and never even considered that it maybe a fouled cc.
beemboy
Mar 14, 2016 11:10 AM
hook3549
Sep 30, 2015 03:22 PM
R53Owner
Mar 30, 2011 04:10 AM
ViVi^BoY
Oct 28, 2007 12:46 AM
jblow
Mar 20, 2007 02:09 PM
