R56 Timing determination for 07 MCS engine install
Old Sep 22, 2023 | 08:09 PM
pointdexzter's Avatar
pointdexzter
Could someone tell me or point me in the right direction.
How do I determine I have locked the crankshaft in the right position
before I place the cam lockes on during the timing process
Old Sep 23, 2023 | 10:11 AM
Yoshimura 1's Avatar
Yoshimura 1
The crank locking tool will not go into the transmission hole.......the pistons will all line up half way
the block also you should be able to see the numbers facing upwards on the came......
Old Sep 23, 2023 | 05:24 PM
pointdexzter
Youhsimura,
Thanks, you know the crank goes around twice for one revolution of the cams.
So, there is a 50% possibility that you could be right or off by180 degrees.
This is applicable if you were locking a running car.
Old Sep 24, 2023 | 11:27 AM
mkov608's Avatar
mkov608
Rotate the cranksahaft center bolt (18mm) clockwise (clockwise only) until the writing on the center of each camshaft is at the 12 o'clock position. Then insert the crankshaft locking tool. It's not possible to be 180 degrees off because there is only one hole in the flywheel.
JimmyG9146
19
Sep 13, 2024 02:53 AM
danraabe
Oct 21, 2019 02:50 PM
Stokersrule
Apr 28, 2016 07:40 AM
bimmertek
Jan 27, 2014 06:11 AM
MiniMacster
Oct 28, 2013 08:03 AM
