R50/53 2003 mini cooper s
Old Sep 8, 2023 | 04:32 PM
danalb's Avatar
danalb
Old Sep 8, 2023 | 08:41 PM
Onizukachan's Avatar
Onizukachan
Good question. You’ve confirmed Voltage is good at rest with no load, but it also takes amperage to turn over a starter. Turn on all the lights, radio, ac, ignition etc amd measure the voltage under load. See if it is dropping significantly?
or take the battery to be load tested to see if it is still good or might have a bad cell or two.
Old Sep 9, 2023 | 09:06 AM
Daftlad's Avatar
Daftlad
+1 for getting the battery tested. If it's consistently starting with a jump it's most likely not the starter.
Old Sep 9, 2023 | 06:52 PM
cooper48's Avatar
cooper48
^^^ What they said. Just went through the same thing with my R53 -- 12.9 across the battery, 14+ while running (after charging the battery to 100% and starting once). After that start, back to nada. New battery solved the problem.
danalb
Sep 8, 2023 04:35 PM
bahman
Apr 17, 2018 07:39 AM
LaCoppola08
MINI Camera and Video
May 22, 2011 06:13 AM
eddiemonster
MINIs and Minis for Sale (archive)
15
Jun 7, 2008 06:41 AM
Innes
11
Oct 28, 2002 03:03 PM
