R60 Tail light issue
Old Aug 20, 2023 | 08:26 PM
keebler's Avatar
keebler
Driver side top bulb went out, looked like overheating. Replaced the bulb, but didn't fix it. Replaced the whole assembly, did not fix.
Swapped board with the passenger side, passenger side works.
Put back into driverside, does not work.
Is there a fuse I am missing? Or could it just be the footwell module?
Checked with Bimmerlink and it is giving an error for the light, cleared the error and the bulb is still out, and warning light is still active.
Possible note, Driver side fender lights also died, swapped bulbs and they are up and running.
So I am under the impression there is a wiring fault somewhere but wanted to narrow down the electrical issue before tracing wires and removing the footwell module for testing.
Only light out currently is driver side, top of the tower.
Old Nov 6, 2024 | 04:19 PM
mrbrains99's Avatar
mrbrains99
Were you able to fix it?
I am having the exact same issue - top passenger side rear bulb is out, replaced the whole lightbulb unit, still doesn't work. I suspect it's the wiring harness, but not sure.....
Thanks!
Old Nov 6, 2024 | 04:27 PM
keebler's Avatar
keebler
Thanks!
so i was able to fix this… Damn software lock.
i used a bluetooth obd and Bimmerlock app to unlock the error which was caused by that bulb going out.
short circut lock was active. Once i reset it was working again.
Old Dec 21, 2024 | 09:01 AM
Koka's Avatar
Koka
I have checked locks as well, but solution was..ahm..little embarrassing -
Driver side white rear view lamp is operating as a FOG light so only one bulb is for reverse drive light, second one is for rear FOG light
Old Jan 21, 2025 | 08:49 AM
Accarrow's Avatar
Accarrow
I'm new to mini cooper stuff but have a similar issue with my r60 tail lights. Did you need the full version of BimmerLink to do this?
eljay
Sep 2, 2022 09:01 AM
Ellimac84
R57 :: Cabrio Talk (2009+)
Apr 22, 2019 01:06 PM
destr0
Electrical
Apr 5, 2018 05:38 AM
cry7670
Jan 19, 2016 11:49 AM
chilipepr
Oct 23, 2010 06:57 PM
