R56 Airbag Reset
Old Aug 15, 2023 | 07:51 AM
ptkacik's Avatar
ptkacik
Airbag Reset
Does anybody have experience with replacing a steering wheel airbag? Mine just blew (very mild collision, nobody hurt) and I was going to swap it out. Does the airbag controller need to be replaced? Is there a dealership reprogramming needed? Can I reset it with a Foxwell NT-510 scanner?
Thanks,
Peter
Old Aug 16, 2023 | 12:31 PM
ptkacik's Avatar
ptkacik
Really? Nobody has ever replaced a steering wheel airbag?
Well... When I figure it out, I'll report back.
Peter
Old Aug 16, 2023 | 02:40 PM
gauss66's Avatar
gauss66
I just googled - so do not know how accurate this is - but hope it helps !
Old Aug 16, 2023 | 06:25 PM
ptkacik's Avatar
ptkacik
Wow! Thanks. Just disconnect the battery, pop it out, disconnect it, connect up the new one, pop it back in place, and reconnect the battery.
No brain box reset or anything.
I’ll be doing this tomorrow.
Thanks,
Peter
Old Aug 17, 2023 | 11:35 AM
Yep, but you might have codes that say the airbag deployed. If the modules/sensors on the body are damaged from the crash/ locked out, you may have issues with the system not deploying again.
You can reset the airbag light with the schwaben tool, but if the system says their is a permeant fault from crash, nothing can be done except dealer level and making sure those sensors for the airbag system are ok.
I would just have them scan it at the MINI dealer and make sure the system still functions, not worth the risk.
condor27596
Oct 18, 2010 01:04 PM
seigmann
Jul 11, 2008 08:23 PM
mokmokmini
Jan 25, 2008 01:33 AM
