Hi Yall, I have a 2013 MCS. It has had a turbosmart dual port BOV installed for quite some time, and I am in the process of switch to the Turbosmart plumb back recirc valve and I have an issue.
The dualport that I am removing had no connector plugged into it, and i cannot find the right connector to plug in to the new BOV.
For your info, it was a previous iteration of their dual port valve that tapped into the vacuum system on top of the intake with a tap and tube running to the BOV.
I am seeing 2 dummy plug right near there that look to be PCV heater hoses, but where is the plug that goes into the BOV?
I have the M7 silicone intake boot hence the need for PCV heater delete..
I need to find the plug for the BOV that would plug into this:
And all i can currently find are what look like these pcv heater connectors which look like this:
