R55 Could use some advice Aisin troubleshooting
Old Jul 27, 2023 | 04:51 PM
techspy's Avatar
techspy
I will try to keep it short.
2008 clubman s with approx 170k miles. Started getting a 3-4 shift flare. Thought it was the K2 Clutch Seal Ring Sleeve issue so ordered the fix kit for that and a general rebuild kit. Turned out the issue was not teh sleeve but a blown seal on one of the pistions. Got it all back together and got a p0970, pressure control solenoid c control circuit low and only had reverse and 5th gear. Figured it was a loose wire/plug. Dropped the valve body, checked everything, replaced the output speed sensor (original one was a bit beat up due to having to tap it out but didnt have the replacment when I put it together so figured I would replace it now). Code cleared up and able to drive. Sport mode was fine but some flaring and bumping in normal mode. Figured it just needed to relearn a bit. Parked for about 4 hours. got back in, reversed out of the garage and when I put it into drive got nothing. Then tried reverse again, nothing. Just revs. Got it back in the garage, let it sit for about 2 hours and it would engage reverse then back into drive and only engaged for a few seconds. Thought it may be low on fluid so added a bit more and no change. No codes and using a scan tool all info seems to look correct. Shows proper gear selections, rpms etc.
I can get a used trans for $200 so will prob pick that up tomorrow and roll the dice. The shame is the engine is fine, doesn't burn/leak oil. The body is perfect, no rust and clean as hell inside and out. Please tell me there is something simple I missed that is causing this! Thanks
GSequoia
Feb 20, 2026 10:55 PM
majikz666
Sep 27, 2022 05:24 AM
Aspen
Jul 30, 2021 12:59 PM
Noahl
Feb 4, 2020 10:06 AM
apekim
Jun 26, 2019 06:01 AM
