R57 Replacing convertible top weatherstripping at body?
Old Jul 25, 2023 | 04:49 PM
wkearney99's Avatar
wkearney99
I'm noticing some cracking of the rubber weatherstripping (or whatever the proper name is for them) where the convertible top fabric meets the body. At the curve of the fenders and along the trunk.
How much effort is involved in replacing these pieces?
Old Jul 26, 2023 | 04:37 AM
wkearney99's Avatar
wkearney99
I did some digging and see there's a thread on this already. I take it the $600 kit comes with both seal already attached to the chromed trim pieces?
Anyone used just seal kit? Seems a bit more cost-effective if the trim is in good shape.
Old Jul 26, 2023 | 06:56 AM
https://www.northamericanmotoring.co...k-out-for.html
https://www.northamericanmotoring.co...ng-away-4.html
Universal fix kit aka
Convertible Top Rear Trunk Molding Repair Kit R52 R57 F57 MINI
: https://www.ecstuning.com/b-assemble...37123437kt1kt/
We have the kit and people have used the low cost kit for the R52-R57-F57, looks good if your trims are not completely shot. If they are cracked beyond the trim or the chrome part is yellowed or damaged then they kit will not hide those and you will have to do the whole trim linked below in genuine MINI. Those links above show what people did with our kits on R52 and R57. F57 would be the same set up.
If you get the Genuine MINI parts make sure you pick the R57 kits, R57 MINI Convertible trim kit https://www.ecstuning.com/Search/Sit...h/54347375319/
People mix the Genuine MINI trims up all the time because they see R52 or F57 trims are cheaper at the time and they do not fit as a work around.
Old Dec 16, 2023 | 07:55 PM
slimjimtell's Avatar
slimjimtell
This is another rear seal option for you.
Old Dec 18, 2023 | 07:13 AM
Mine is cracked beyond the rubber on the top so I have to do the whole trim. After a while the rubber on the top goes above the metal trim (bonded part) and now my seal on the trunk part is shot and pealing. Its starts to peal and is the little gasket on the top to the trunk lid. So its whole new trims for me.
Old Mar 29, 2024 | 11:33 AM
tothemax's Avatar
tothemax
I see this is an older thread, before creating a new one thought I would reach out here, hoping to get some info. My wife has a 2012 Cooper R57 and a few months ago we noticed that the trunk was holding water, a considerable amount under the toolkit holder. The entire trunk area was wet and it took a while to dry it out. As a interim fix I ordered a car cover from Amazon and we use it when it rains, that has been working. I ordered the trim kit and am waiting for the weather to warm up as we don't have a garage. The top is in pretty good condition, there were a few openings in the seams along the glued section (fabric folds) alongside the rear window that I sealed with a silicone sealer (seemed to work well).
I guess my main question is if the side seams are the place where the water is leaking in, they are cracked and need to replaced anyway. Just want to make sure that I am addressing the main problem.
I'll appreciate any feedback on this.
Max
Rear top seal, cracked
Right rear seal cracked
Window fold, sealed with silicone sealer
Old Apr 1, 2024 | 09:33 AM
Seal kit linked above for that fix. :
For this one i would get a new top. That ones looks like its patched and will leak again.
They are made by Harrtz and some places have them aftermarket at convertible top shops. https://www.northamericanmotoring.co...ent-guide.html
https://www.realoem.com/bmw/enUS/sho...diagId=54_0404
https://www.ecstuning.com/Search/Sit...h/54342758078/
Old Apr 2, 2024 | 08:58 AM
JAMADOR's Avatar
JAMADOR
Semi-related
Looking at an R57 with a partially detached rear window. Any reliable repairs for that, or is a new top the only real viable option?
Also @ECSTuning
The links you posted above to your site & RealOEM, are these the same top? The RealOEM option has about $800 savings, comparing black to black.
Old Apr 2, 2024 | 11:20 AM
realoem is not a buying site, its just an old internal catalog MINI "ETK", those prices are not correct at all. Our prices are.
People seal the rear glass at a convertible top place, sometimes it works but most people just get a new fabric top. It includes new glass that's bonded
https://www.northamericanmotoring.co...g-unglued.html
Folding Top Fabric - Black (Most common color)
Other options: Otherwise new tops are here and any upholstery shop could replace it. There are 4 different colors. I guess you could change the color while you are at it. 54342758078, 54347310524, 54342758301, 54342758300
Old Apr 2, 2024 | 11:23 AM
JAMADOR's Avatar
JAMADOR
Thanks, the R57 I'll be picking up is triple brown, wouldn't mind going to a black top if I go the replace route, once I get a better idea of how/where it's leaking.
May look into wrapping it down the road, easier to change colors with a black top than picking something that flows with the brown.
Old Apr 2, 2024 | 11:36 AM
Welcome.
Thats brown top was an option. https://www.ecstuning.com/Search/Sit...h/54347310524/
It was on the MINI Highgate. It was the first top with infused metallic thread for MINI and BMW group other then Rolls Royce.
Changes color in the sun.
https://www.bmwblog.com/2012/02/03/m...e-convertible/
FS:: Mini Cooper S Convertible Highgate Edition - North American Motoring
Old Apr 2, 2024 | 11:39 AM
JAMADOR's Avatar
JAMADOR
I don't think this one is a Highgate, just a base Cooper with the HC leather.
Old Apr 2, 2024 | 12:06 PM
ok, so HC withy HC interior, black top. Yes Highgate was later in the r57 life. All the r57 tops can be swapped, some people do that for a color change.
Boxersuss
Oct 17, 2012 09:31 AM
Tamson
15
Aug 19, 2007 06:53 PM
Gerldoc
17
Jul 6, 2006 09:29 PM
gbsher
Off-Topic :: Autos
Dec 17, 2004 10:50 AM
