2019 F60 brake bleeder recommendation
Old Jul 22, 2023 | 10:36 AM
minor1000's Avatar
minor1000
2019 MINI Countryman S ALL4 Hatchback
I have a lot of experience bleeding brakes manually with two people, but I never used a power bleeder. (I've never bled brakes proactively, but I'm just trying to follow directions from the mini nag.) There are a lot of different brands and versions of bleeders, almost as bad as buying a vacuum or electric toothbrush, but not quite!
Just looking for one that will work well for my F60.
Appreciate any suggestions - thx
Old Jul 23, 2023 | 07:38 AM
thefarside's Avatar
thefarside
The Motive brand is recommended by an auto tech I use.
Harbor Freight stuff looks like total crap.
Old Jul 23, 2023 | 03:12 PM
cooper48's Avatar
cooper48
^^^ I have a Harbor Freight brake bleeder and it works easily and perfectly. You do need a compressor, however, to use it. I also have a Motive and it doesn't work as well as the HF version.
Old Jul 23, 2023 | 05:31 PM
minor1000's Avatar
minor1000
i have a compressor, but good to know about that. i’ll have to look at their ad again because i didn’t see that
Old Jul 30, 2023 | 03:40 AM
Mini-Titan's Avatar
Mini-Titan
I have a Schwaben-brand I got on sale from ECS Tuning. Worked perfectly.
Old Aug 1, 2023 | 06:51 AM
cjv2's Avatar
cjv2
I also used a Schwaben hand-operated unit for my 2017 Cooper S. Specifically, this one. And absolutely best plan to use a catch bottle -- I honestly can't imagine doing this job without one of sufficient quantity and with a hanger of some kind (whether product-ized or DIY). I used this one (also a Schwaben product).
Old Aug 1, 2023 | 06:52 AM
+1 thats the exact same one i used on my R58 and R52. Repaired the rusty brake line on the R52 when i rebuilt the who suspension.
Old Aug 1, 2023 | 11:13 AM
Jason Cornelius's Avatar
Jason Cornelius
I have had good luck with the motiv on my old R55s, and the R53. Have also used it successfully on another R55s and R60s.
Old Aug 10, 2023 | 09:45 AM
WhatV8's Avatar
WhatV8
I have always relied on vacuum bleeding from the caliper vs power bleed from the reservoir...just my preference and never had an issue, even with ABS style systems. I use a Mityvac MV8500 Silverline kit on all my vehicles, works great and lets me feel a bit more in control for the rate at which you pull the new fluid into the system, YMMV.
https://www.skf.com/mityvac/products...mp-kits/mv8500
Old Sep 23, 2023 | 02:55 PM
TVPostSound's Avatar
TVPostSound
I see a lot of complaints regarding the Schwaben cap not sealing and brake fluid squirting out.
There are YT videos showing how rio add an oring inside the cap to help,
Old Sep 25, 2023 | 11:07 AM
cjv2's Avatar
cjv2
I did not run into this but who knows what might happen at next go -- I will locate those YT vids. Thx for the heads-up!
Old Oct 23, 2023 | 05:20 PM
TVPostSound
This one.
The idiot didn't bother putting a wind muff on the microphone.
Old Oct 24, 2023 | 08:44 PM
cjv2's Avatar
cjv2
This one.
https://www.youtube.com/watch?v=Yfz9RlvKO0c
Definitely appreciate this. That's the unit I have, and I suppose I got lucky -- no leaks, was at 15psi, did the whole car (and I wasn't exactly fast about it). But the next time around, who knows. I foresee an O-ring in my future.
Thanks much!!
Mister Spice
131
Jan 18, 2023 09:13 AM
MiniAdv
Dec 9, 2019 05:30 AM
CG1*
Tires, Wheels, & Brakes
Aug 10, 2019 10:01 AM
DarkMiniCooperS
May 26, 2017 06:21 AM
vpoonai
Mar 8, 2017 04:08 PM
