F55/F56 Belt line bodywork clips broken - can they be replaced?
I went about replacing the chrome belt line with the genuine Mini black belt line on my F56 JCW today.
During the process and despite being careful a couple of the plastic clips disintegrated in places meaning I have a slight gap between some of the beltline and the bodywork.
Can these plastic clips be replaced? (Parts 3 and 5)
The resulting panel gaps
# 3 4 and 5 are the clip into parts on the rear beltline
https://www.realoem.com/bmw/enUS/sho...96#51377300028
https://www.ecstuning.com/b-genuine-...n/51137302545/
https://www.realoem.com/bmw/enUS/sho...diagId=51_9300
These clip into those pieces and that's all you can get.
https://www.ecstuning.com/Search/Sit...h/51377300019/
https://www.ecstuning.com/Search/Sit...h/51377300020/
https://www.ecstuning.com/Search/Sit...h/51137320540/
If you want to change the whole looks you can get the blackline beltline kits.
F56
https://www.ecstuning.com/Search/Sit...h/51135A0B944/
F56 install (f55 pretty much the same) https://www.northamericanmotoring.co...-waistlin.html
F55
https://www.ecstuning.com/Search/Sit...h/51135A0B943/
F56
F55
ECS - thankyou for your reply.
I already have swapped to the Mini black beltline kit:
The issue is the mount Rails that run along the bodywork the above beltline trim clips into.
Can these mount rails be replaced?
Part numbers 51377300023 and 51137302545 from the realoem page you linked to.
Yes they clip on the bodywork shoulders.
Thats great you got them.
Couldn’t refuse for £275
So these clips for the bodywork shoulders - do they just clip / slide in easy enough?
Clip on the metal body on the shoulder and then you clip on the trim to that. Glad to help
Until I sort the clips (I think the rear quarter one is just unseated) - it won’t cause any water ingress issues into the car will it?
Welcome,. side panel i dont think their is a weep hole for the water. Might get a little water in the side panel, but have not dug into the F56 platform myself.
Trunk lid has a weep/drain hole as the bottom, so the back should be fine.
Thing is - to the left of that is a gap between the rear window trim and glass that water goes down anyway?
I still would just tape along the entire molding until it's fixed. The water will just run over the tape.
Yep i would use something like electrical tape. That way it will match. Hopefully it will stick or painters tape which i know will stick.
Removed and reseated - the ‘blade’ that secures the waistline trim into the retaining clip groove wasn’t seated correctly.
Now sitting fine:
Another issue discovered - non functional rear wiper - time for another thread 🤦🏼
Now sitting fine:
Now that's better
But stinks about the wiper, did you unplug something? Remove the rear inside panel?
No interior panels or electrics touched as only had the car 3 weeks and luckily it’s in warranty so will be claiming!
Mini nurse
F54 :: Clubman Talk (2015+)
May 10, 2018 06:28 PM
not-so-rednwhitecooper
Nov 5, 2006 06:03 PM
