F55/F56 Belt line bodywork clips broken - can they be replaced?
Old Jul 21, 2023 | 03:32 AM
gex23's Avatar
gex23
I went about replacing the chrome belt line with the genuine Mini black belt line on my F56 JCW today.
During the process and despite being careful a couple of the plastic clips disintegrated in places meaning I have a slight gap between some of the beltline and the bodywork.
Can these plastic clips be replaced? (Parts 3 and 5)
The resulting panel gaps
Old Jul 21, 2023 | 06:06 AM
MINIBMAN's Avatar
MINIBMAN
I'm sure you can get replacement clips from your dealer. I just received my 24 JCW and that's was the reason I wrapped mine instead of replacing and taking a chance of breaking things.
Old Jul 21, 2023 | 07:04 AM
# 3 4 and 5 are the clip into parts on the rear beltline
https://www.realoem.com/bmw/enUS/sho...96#51377300028
https://www.ecstuning.com/b-genuine-...n/51137302545/
https://www.realoem.com/bmw/enUS/sho...diagId=51_9300
These clip into those pieces and that's all you can get.
https://www.ecstuning.com/Search/Sit...h/51377300019/
https://www.ecstuning.com/Search/Sit...h/51377300020/
https://www.ecstuning.com/Search/Sit...h/51137320540/
If you want to change the whole looks you can get the blackline beltline kits.
F56
https://www.ecstuning.com/Search/Sit...h/51135A0B944/
F56 install (f55 pretty much the same) https://www.northamericanmotoring.co...-waistlin.html
F55
https://www.ecstuning.com/Search/Sit...h/51135A0B943/
Old Jul 21, 2023 | 07:20 AM
gex23's Avatar
gex23
ECS - thankyou for your reply.
I already have swapped to the Mini black beltline kit:
The issue is the mount Rails that run along the bodywork the above beltline trim clips into.
Can these mount rails be replaced?
Part numbers 51377300023 and 51137302545 from the realoem page you linked to.
Old Jul 21, 2023 | 08:11 AM
Yes they clip on the bodywork shoulders.
Thats great you got them.
Old Jul 21, 2023 | 09:15 AM
gex23's Avatar
gex23
Couldn’t refuse for £275
So these clips for the bodywork shoulders - do they just clip / slide in easy enough?
Old Jul 21, 2023 | 09:56 AM
Clip on the metal body on the shoulder and then you clip on the trim to that. Glad to help
Old Jul 21, 2023 | 01:51 PM
Joe6022's Avatar
Joe6022
Yo that wrap is sick!!!
Old Jul 21, 2023 | 11:58 PM
gex23's Avatar
gex23
Thankyou ECS.
Until I sort the clips (I think the rear quarter one is just unseated) - it won’t cause any water ingress issues into the car will it?
Old Jul 24, 2023 | 01:10 PM
Welcome,. side panel i dont think their is a weep hole for the water. Might get a little water in the side panel, but have not dug into the F56 platform myself.
Trunk lid has a weep/drain hole as the bottom, so the back should be fine.
Old Jul 24, 2023 | 08:49 PM
gex23's Avatar
gex23
You think water will be building up and sitting in the side panel?
Old Jul 25, 2023 | 04:41 AM
MINIBMAN's Avatar
MINIBMAN
I would 100% put some blue painters tape over it for now until you get it fixed.
Old Jul 25, 2023 | 04:49 AM
gex23's Avatar
gex23
Thing is - to the left of that is a gap between the rear window trim and glass that water goes down anyway?
Old Jul 25, 2023 | 05:09 AM
MINIBMAN's Avatar
MINIBMAN
I still would just tape along the entire molding until it's fixed. The water will just run over the tape.
Old Jul 25, 2023 | 05:54 AM
Yep i would use something like electrical tape. That way it will match. Hopefully it will stick or painters tape which i know will stick.
Old Jul 25, 2023 | 08:47 AM
gex23's Avatar
gex23
Removed and reseated - the ‘blade’ that secures the waistline trim into the retaining clip groove wasn’t seated correctly.
Now sitting fine:
Another issue discovered - non functional rear wiper - time for another thread 🤦🏼
Old Jul 25, 2023 | 08:51 AM
Now that's better
But stinks about the wiper, did you unplug something? Remove the rear inside panel?
Old Jul 25, 2023 | 08:55 AM
gex23's Avatar
gex23
Now that's better
Nothing at all - literally just removed the exterior trim.
No interior panels or electrics touched as only had the car 3 weeks and luckily it’s in warranty so will be claiming!
Old Jul 26, 2023 | 04:49 AM
MINIBMAN's Avatar
MINIBMAN
Glad to hear you got it sorted
Mini nurse
F54 :: Clubman Talk (2015+)
May 10, 2018 06:28 PM
jduplooy
Mar 11, 2009 04:08 PM
not-so-rednwhitecooper
Nov 5, 2006 06:03 PM
