How To Intake Valve Cleaning / Top Dead Center
Old May 19, 2023 | 09:01 PM
Reusable-Box's Avatar
Reusable-Box
Unhappy Intake Valve Cleaning / Top Dead Center
I am an idiot. There are a number of youtube videos that talk about cleaning the intake valves, and I have reason to believe they're going to be filthy with carbon. I want to clean them. All three of the videos skip over actually getting the damn thing to top dead center. I know I should be able to turn the camshaft with the crank bolt/pulley but I can't seem to find it. I don't need to pull off any of the other timing stuff do I? I can see several pulleys but none of them look like what I want.
Can anyone provide any visual aide for me? Or a video that actually covers this? Or any other good way to make sure the intake valves are closed so I don't get crap in the engine?
Old Dec 1, 2025 | 01:29 PM
MiniConn's Avatar
MiniConn
If you pull the passenger wheel and peel back the wheel liner you can access the crank bolt. I pull the spark plugs and use a long screw driver in the cylinder to watch when piston is at TDC. With the intake manifold off you can verify valves closed with a mirror or bore scope then get after it.
Old Apr 19, 2026 | 09:44 AM
Raymo2u's Avatar
Raymo2u
If you are worried about getting stuff into the chamber, when you are done doing the cleaning - leave the spark plugs out, disconnect the fuse for the fuel pump and crank the car over a few times. Anything in the chambers will be shot out.
Or take some compressed air cans and spray into the intake ports with the plugs out.
Texasbaehr
Oct 3, 2022 06:56 PM
Paul CC
Sep 9, 2020 11:35 AM
timski
Jul 12, 2017 11:03 AM
jbruns29
R55 :: Clubman Talk (2008+)
Apr 25, 2014 09:11 AM
