Suddenly the fuel pressure drops
Old May 14, 2023 | 12:30 PM
mjavila16's Avatar
mjavila16
Hello friends, I have a problem that I have been going round and round. I have a mini cooper n14 turbo 2010. 5 months ago I rebuilt the engine, 2 months ago the high pressure pump began to fail, I changed it for a new OEM one, then 1 month ago the tank fuel pump fail. Today I changed the tank pump and the car does not raise pressure on the rail more than 80 psi. If I turn it on and off it gets to 600-700 psi at idle. but when driving it and walking more than a block the pressure drops back to 80 psi.
Checking the HPFP I see that it has oil, is it normal or the pump already defective.
Old May 14, 2023 | 01:30 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Im trying to make sense of these statements… If the engine is not running, but the key is on, the fuel rail pressure should be ~80 psi. If the engine is running at idle, the rail pressure should be ~700 psi. When driving down the road, the rail pressure will go up to ~1700-2000 psi.
If any of those conditions are not met, something is wrong.
Old May 14, 2023 | 02:09 PM
mjavila16's Avatar
mjavila16
Ok, in the morning it turns on the third time I press the power button. The car starts hard but stays on. By OBD2 I see that the pressure is at 80psi, it does not go up to 700psi at idle. If I start to accelerate the car reaches 700 psi. But the minute the car is started the pressure drops to 80psi. But the car does not turn off
Old May 15, 2023 | 03:42 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
That sounds to me like the high pressure pump is failing
Old May 16, 2023 | 08:21 PM
mjavila16's Avatar
mjavila16
Old May 17, 2023 | 04:02 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
There you go! Looks like you have a new HPFP in your future
OregonMike
R55 :: Clubman Talk (2008+)
Nov 28, 2022 11:23 AM
Jake Rosser
Feb 6, 2020 06:19 PM
bimmerwrench
Jan 26, 2020 01:22 PM
Zpgray19
Apr 25, 2017 12:31 PM
Sep 1, 2015 03:36 PM
