R50/53 ABS and Brake light on, yet to be driven
Old May 10, 2023 | 09:02 AM
Juan442's Avatar
Juan442
I've a 2002 R53, 75,000 miles, six speed. Rare to see rain, and never snow. Garage kept. Nearest dealer 3 hours away, thus stuff myself. Brake fluid replacement 2 years ago, as always. I always use the pressure system, MOTIVE.
This April, with a very nice day, started it in the garage, didn't touch brake pedal, both ABS and Brake lights immediately came on. Checked fuses and fluid level with everything ok. Took for a very short drive, and no braking issues, ran and braked fine. Brakes are very good shape.
Reviewing I get the idea either a wheel sensor or ABS has failed. Wheel sensors can be checked via ohm meter, but if not then need scanned.
Only one place can scan. Cost $100 for scan and to look over any issues. I suppose I'll get it scanned for sensors and ABS, or other issues.
Two questions:
1. What happened?
2. Its time for a scanner to not only use for MINI, but other cars as well. Not only trouble shoot, but support ABS bleeding? In $300 range.
What comes to mind?
I love my lady, and we have fun.
Juan
Old May 10, 2023 | 12:30 PM
Hello,
https://www.northamericanmotoring.co...-on-tight.html
Sometimes the head cracks from age or the back of the wheel bearing wears into the sensor face due to rust. Mine did.
Schwaben scan tool can tell you which one is bad, you can also play around with sensor and then scan and clear to see if its a bad socket or connection.
https://www.ecstuning.com/b-schwaben...020sch01a~scf/
Old May 11, 2023 | 08:33 AM
Juan442's Avatar
Juan442
Thank you. I've a Bentely book showing how to do this. Of scanner(s), I like you suggestion. Thinking, service place is 5 miles away, may be all day wait, then who knows what he'll say, plus not sure how brakes may perform.
An issue has just come up, likely be week after next.
Will keep advised.
Old May 11, 2023 | 09:02 AM
Ok glad to help, yep we have the scanner and the Bentley, Forums are great for info outside of those two critical tools.
Old May 12, 2023 | 07:26 AM
Daftlad's Avatar
Daftlad
Would also score a copy of this bad boy, the Bentley companion piece, 'MINI Cooper 2002-2006 Cooper, Cooper S; Diagnosis Without Guessowork' worth every dollar:
http://www.bentleypublishers.com/min...2002-2006.html
Amazon Amazon
Old May 16, 2023 | 09:05 PM
noodlesandsam's Avatar
noodlesandsam
It could be a sensor - the cars are 15 + years - my 05 r53 needed both fronts at 125K ( 7 years ago ). I do have the scanner in the ECS pic. It will tell you which sensor is bad ( or if it is due to the abs unit ). If code readers are that far away, it is good to be self sufficient.
Old May 23, 2023 | 06:48 AM
Juan442's Avatar
Juan442
Have a new grand daughter. Wanted to be there to welcome her.
Of scanners, what about a ThinkScan 660? For I have a VW also.
Old May 29, 2023 | 11:00 AM
Juan442's Avatar
Juan442
Update: Took MINI to Advance auto. They use an Autel scanner, but I did not see its #. Plugged showed no codes....hmm.
Across the street is Autozone. They have their own scanner showed an ABS code. Inside and hooking to their computer, trouble code shows: 5DF5 - Control Unit Internal Failure additional diagnostic work is needed to determine the issues with your vehicle. This print out shows "Powered by Innova" with milage.
Questions:
1. With 5DF5 listed, means the ABS module needs replaced and/or repaired?
2. If can be repaired who can do this?
3. Nonetheless, I need a scanner, that can also do ABS bleeding. I do have a MOTIVE bleeder.
To help others, there is an excellent YouTube showing how to remove and reinstall the ABS module. Search: "Replace Mini Cooper ABS module", then scroll down to: "Coats and Gaiters" It seems straight forward..
John
Old Jun 2, 2023 | 01:52 PM
Onizukachan's Avatar
Onizukachan
BMW scanner 1.4 is about $20 with cable and I have used it on the r53 parts/donor car to determine what caused the ABS light on it… just need an old laptop that has windows Xp or similar. I also have bmw DIS on that same laptop with inpa cable and switched it to the Mini version.
Between the two you’d be pretty covered.
and then you can add NCSexpert amd NCS for dummies and do your own settings, drl on/off, auto lock. On/off, comfort opening and closing, unlock with ignition off, and all the other sundry things you can activate and deactivate to your personal taste!
Old Jun 8, 2023 | 08:30 AM
Juan442's Avatar
Juan442
Update:
I lost the odometer about a year ago. Seems it is connected to a wheel sensor. Losing this sensor may define problem. Nonetheless, I will get a scanner that should pinpoint this problem. I've decided on ECS Scwaben scanner dedicated to BMW/MINI/RR. Maybe someday a RR.....not.
Of Windows scanner, I'll keep that in reserve.
Will advise.
John
Old Jun 19, 2023 | 12:01 PM
Juan442's Avatar
Juan442
Update:
Got an ECS Pro BMW/MINI/RR scanner week before. Plugging it stated, "System corrupt"...Ouch. ECS immediately issued a return and new one arrived last week. This works, but I've yet to really get into how to use it. Cool that it checks brake fluid level, plus a lot of other stuff. Does have a brake bleed function but yet to deal with that. Did find wheel sensor tests, but yet ABS module live data review.
I suggest the operator manual be better written.
Its worth the money.
If anything comes up will update.
John
Old Jun 25, 2023 | 07:04 AM
Grand-Cayman's Avatar
Grand-Cayman
ABS sensors are easy to clean and/or replace. I had one 'go bad' but it was just dirty.
Old Jun 26, 2023 | 08:33 AM
Yep the head can get dirty or the pins don't line up in the plug and get bent, watch for that.
Old Jun 26, 2023 | 08:43 AM
Juan442's Avatar
Juan442
This scanner has a live function. Driving, (4) sensors displayed the same speed. With fuses, fluid level, and sensors ok, ABS is the issue. Therefore, best to get repaired or replaced.
Studied how to repair or replace. Calling/email, several places have poor BBB comments; do not have physical addresses or from a home; Can ship to me yet not forward module numbers; I offered to bring mine to a "location". Phone person said, "No one here, on vacation till end of August".
I may have to go to ISTA. Get a close part and re-code, or simply use the one I have.
Bit of a "Catch 22".
Old Aug 18, 2023 | 09:12 AM
Juan442's Avatar
Juan442
Sorry for delay, been in CA.
I found a company in the UK that rebuild these. The company is ECUtesting.
They provided shipping label and ABS arrived in two days. Three days later emailed with an internal fault found. Total cost was $300. Didn't ask for payment until my decision. Shipped and received quicker than expected. This also includes a lifetime warranty.
I installed yesterday, cleared codes and everything is ok. Used ECU BMW/MINI scanner to bleed. It stated to use a power bleeder, like Motive Products.
Bit of pain to remove it, for its in there tight. Harder to put back. I used flared wrenches, plus a crows foot to set brake lines to proper torque. Stuff shop towels everywhere for there are small bolts and nuts you don't want to drop.
If your ABS is more common contact ALLMAG Auto Parts. This is a good company. They sent one for $88, plus for $9 get a 6 month warranty. Would require re-code. I didn't want this. Returned with no problem.
John
Mini Putt
18
Sep 20, 2023 01:34 PM
Tiutiu0522
Dec 14, 2016 07:21 AM
Shoe Coupe
Dec 11, 2012 10:45 AM
psyfer
Canada
Jul 31, 2012 06:47 AM
jankey
Dec 17, 2007 04:22 PM
