Mystery oil leak
Old Apr 25, 2023 | 12:14 PM
iissac22's Avatar
iissac22
Mystery oil leak
Hi everyone. I own a 11’ Mini Cooper Countryman S 2wd with 160,000 well maintained miles. I have an oil leak from up high on the right front side of block that flows down and leaks. I am using the photos above just to show the location. Have you seen this and what could it be?
Old Apr 25, 2023 | 01:04 PM
2014 MC's Avatar
2014 MC
Would seem like a valve cover leak to me.
Old Apr 25, 2023 | 01:28 PM
iissac22's Avatar
iissac22
seriously! Ok I will go back and check Could there be anything else causing it? To leak like that?
Old Apr 25, 2023 | 01:33 PM
2014 MC's Avatar
2014 MC
Based on your picture, it starts at the parting line of the head and valve cover and leaks down to the lower areas. You can try checking the bolt tightness, but that may be a temporary fix if the gasket is going bad which I think is pretty common.
Old Apr 25, 2023 | 04:25 PM
iissac22's Avatar
iissac22
thanks for the response. I changed almost every gasket on the car, when i should’ve just replaced the obvious. Going to replace asap
Bgolden20
R55 :: Clubman Talk (2008+)
Aug 15, 2021 02:01 PM
Blakepadilla55
Aug 5, 2019 08:48 AM
Shoe Coupe
Jan 21, 2013 11:47 PM
coconutmilk
Jun 23, 2010 04:12 PM
