CarPlay is here finally! And it is glorious!
Old Apr 7, 2023 | 02:41 PM
GoneGator66's Avatar
GoneGator66
So I finally bit the bullet and got CarPlay in my 2019 F55. I had the base (BIT?) radio, and @sb2002 hooked me up with a literal “plug and play” retrofit system. He provides a custom harness that makes the install simple and it is fantastic!
Let’s get this out of the way - it’s expensive but well worth it to me. And the process was relatively easy. Once I received the kit, sb2002 helped me with the install via text. Then, he brought in @ndal to code the newest software to the unit and it’s amazing. The touchscreen, colors, display resolution… all top notch. Steve and Nikos know what they’re doing and make the upgrade pretty easy. Hey, if I can do the install, pretty sure anyone can, too.
To quote Ferris Bueller, “It is so choice. If you have the means, I highly recommend picking one up.”
Old Apr 7, 2023 | 03:01 PM
sb2002's Avatar
sb2002
Thanks for the kind words, and more than happy to help.
Old Apr 8, 2023 | 04:17 AM
maaii's Avatar
maaii
Wow retrofit mini BIS to EVO ID5/6 HU with 8.8 touchscreen .
Old Apr 10, 2023 | 10:57 AM
miniRogue1's Avatar
miniRogue1
@sb2002 reveal yourself as the Great Wizard you are... now here's a guy that needs a gofundme.
Anyways, since I've gotten carplay fullscreen, I think I've discovered I might like Apple Maps better. Good job Cook...you might be pulling ahead now.
sb2002
Navigation and Audio
137
Nov 7, 2023 09:59 AM
ukchris
Oct 6, 2022 03:23 PM
AndrewVanis
May 23, 2020 12:53 PM
1ofoneR52
Suspension
Apr 22, 2015 03:49 PM
harhoosh
Nov 6, 2006 03:53 AM
