Clutch slave differences?
Old Apr 2, 2023 | 01:45 PM
idickers's Avatar
idickers
The clutch slave cylinder on my '09 Clubman S is leaking and I got a replacement from the dealer (21526770600). However, it does not seem to seal to the existing clutch line, and brake fluid streams out of the seal between the slave cylinder and the feed line. My old slave cylinder does not have a full part number stamped on it, but it does have "PA66-GF35".
Looking through realoem it appears that there are three generations of clutch slave (21526770600, 21526783622,21526798372), each of which appears to have it's own specific clutch line (21526770598, 21526863945, 21526783623). What is the difference between the 3 versions of clutch slave? Do they each need their specific clutch feed line to seal correct?
Old Apr 2, 2023 | 02:28 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Did you get a new clutch line? What was the condition of the little oring in the end? Sounds like either the oring got damaged, is missing, or didn’t seat correctly.
trini
Jul 4, 2022 12:53 PM
Brandon Fluharty
Jan 12, 2022 09:02 AM
danraabe
Nov 8, 2020 01:55 AM
AngryScotsman
Sep 6, 2019 06:12 AM
sprint1126
Jun 23, 2013 12:40 PM
