F55/F56 source for torque values F56
Old Mar 14, 2023 | 06:51 AM
johnnys2quick's Avatar
johnnys2quick
I have several projects lined up for the f56 this spring. I am planning to run a packed summer of driving events. Can someone please direct me to a good source for a complete list of torque values for the 2017 F56? I am planning a suspension change and installing an LSD and clutch. Being a QA manager I am very fussy about torque specs.
I have searched and can find a specific value at times but i am looking for source for a more complete list.
Thank you in advance. john
Old Mar 15, 2023 | 03:26 AM
Smizrahi's Avatar
Smizrahi
Haynes manual at the beginning of each section
Old Mar 15, 2023 | 05:23 AM
johnnys2quick
yes i have that and it doesn't seem very complete and i will dive into the manual deeper. Does a factory manual exist?
Old Mar 17, 2023 | 08:25 PM
cjv2's Avatar
cjv2
I don't know whether there is a printed/PDF factory manual but I have a 2017 F56 S and access to some stuff. Feel free to hit me up either in-thread or via PM for particular values. On this car I swear by doing it just-so -- I would do that anyway but the BMW MINI is a particular beast so one had better pay attention, right there with you
Old Jan 11, 2025 | 09:29 AM
ChrisHarris's Avatar
ChrisHarris
Hi, would you happen to have the torque specs for the following?
Pivot bolt (front control arms)
Pinch bolt (fca to knuckle)
rear strut bottom bolt (strut to knuckle/trailing arm)
Old Jan 11, 2025 | 09:37 AM
cjv2's Avatar
cjv2
Help me out here -- looks like the doc I have access to is using some different terminology -- is the "wishbone" in this diagram what you're referring to as the front control arm? Guessing yes but want to confirm.
And any other detail you can provide in context of the part names in this diagram will help!
Old Jan 11, 2025 | 09:43 AM
ChrisHarris
Thanks for the quick reply!
Yes, "wishbone" is the front control arm. There's a front pivot bolt for it, as well as its ball joint is held into the knuckle using a pinch bolt. I'd like the torque spec for both of those
"3 spring strut shock absorber" bottom bolt is what I was referring to when I said strut
And by the way, I'm getting conflicting info on the torque for the rear chassis braces. Does your guide have that as well? Thank you!
Old Jan 11, 2025 | 09:50 AM
cjv2's Avatar
cjv2
Here's the full set of what I see pertaining specifically to the front control arm aka wishbone -- will post what I find on the rear chassis braces separately.
Let me know if this helps?
Old Jan 11, 2025 | 09:54 AM
cjv2's Avatar
cjv2
Regarding rear shock absorber/strut to trailing arm:
Old Jan 11, 2025 | 09:58 AM
cjv2's Avatar
cjv2
One more translation exercise -- have a look at this diagram and let me know what "rear chassis braces" translates to in this-diagram-speak and I should be able to get you torque specs.
Old Jan 11, 2025 | 10:08 AM
ChrisHarris
That's an entirely different system. Tha rear chassis braces are back towards the exhaust. Those 2 brigther silver pieces you see towards the center of this photo, one with 6 screws the other with 2 bolts. There may be referred to as cross members
Old Jan 11, 2025 | 10:57 AM
cjv2's Avatar
cjv2
Found 'em.
nutsofamily
Oct 20, 2021 05:38 PM
Stu-mon
Sep 10, 2021 06:11 AM
kyoo
Jul 8, 2014 04:54 AM
blanc71
Apr 26, 2014 09:19 AM
beedeejay
Feb 14, 2014 03:31 PM
