P325f?
Old Mar 8, 2023 | 07:11 PM
Cracolici's Avatar
Cracolici
P325f?
I’m in need of some help, I have a 2013 countryman s all4.
I recently replaced my turbo, and drove it without any issues for a week. And all of a sudden I’ve had two different days where I will try to accelerate and it’ll go into limp mode and throw
P325f. I have tried searching for answers and found no answers. Does anyone have any?
would Appreciate the feedback.
thanks!
Old Mar 11, 2023 | 12:38 AM
robbo mcs's Avatar
robbo mcs
Seems to be linked to 2 separate faults:
First one
Hex 0x36CF
DME, internal fault: Plausibility monitoring, fuel mass
Potential problem source(s): - DME defective
Possible apparent symptoms:- Loss of power- Speed limitation
Only replace the DME if the fault remains present continuously or if the fault frequency is greater than 3
A terminal status switch must be conducted before this fault can be deleted.
Second one
Hex 0x36C9
Control Module Monitoring Fuel Volume plausibility
Potential problem source(s): - Rail-pressure sensor defective. Wiring harness defective. DME defective
Check wiring harness between DME and rail-pressure sensor. Replace rail-pressure sensor. Only replace the DME if the fault remains present continuously or if the fault frequency is greater than 3
A terminal status switch must be conducted before this fault can be deleted..
Old Mar 11, 2023 | 07:56 AM
Cracolici's Avatar
Cracolici
Thanks for the reply, I did Some pressure checking with my scan tool.
it’s coming up at the right idle PSI for the fuel rail pressure, and my max is at the “correct” max PSI.
the only issue I saw Unless I am unaware of how fuel pressure works, when I push On the gas initially the fuel pressure drops a good amount and then gets back to the right pressure… seem right to you?
Old Sep 6, 2024 | 02:32 PM
bodaddy's Avatar
bodaddy
Hey did you ever find out what the problem was? I'm about to send my ecu off to be reflashed. HELP!!!!!!
Old Sep 6, 2024 | 03:06 PM
Cracolici's Avatar
Cracolici
The issue I had was my injectors were bad. I changed them and never had an issue after that.
I don’t have my mini anymore, sold it to my brother last year. But hasn’t had it go into limp mode on him since either.
Old Sep 9, 2024 | 01:56 PM
bodaddy's Avatar
bodaddy
THANKS, i appreciate it
DarkerGolem09
R60/R61 Stock Problems/Issues
Jul 8, 2021 05:08 PM
miguets
May 2, 2020 05:45 AM
pocketmaster
May 17, 2019 09:01 AM
Cracolici
Apr 10, 2019 06:07 AM
wvmtnbiker
Mar 18, 2015 01:44 AM
