R56 Low oil pressure on the highway
Old Feb 19, 2023 | 03:00 PM
Artik99's Avatar
Artik99
Hello, I have a small problem with my 2012 Mini Cooper S. At speeds of 175km/h or higher, I always get the "Low Oil Pressure" warning, but as soon as I slow down to 170km/h, the message disappears. The same thing happened to me with my old 2007 Cooper. I have already replaced the oil pressure sensor, and I use Miller 10w50 oil in the summer and Miller 10w40 oil in the winter.
Thank you for your response
Old Feb 20, 2023 | 07:55 AM
mkov608's Avatar
mkov608
If you have a '12 Cooper S, you can install a scan gauge II and monitor oil pressure since the '12 models (even the justa) use an oil pressure sensor. You can also use a low-priced scan tool like the Foxwell NT530 and monitor the oil pressure via the OBDII port. That's your first step; you need to know what the actual oil pressure is. The other option would be to install a direct reading pressure gauge; you can install the pressure gauge in the oil pressure "switch" port in the cylinder head. In the 2011-2013 models, the oil pressure switch was replaced with a sensor, but the port in the cylinder head is still there. The sensor on the later models is not in a "user friendly" location.
On the '07 (I used to own one), you need to remove the oil pressure switch in the cylinder head and install a direct reading gauge. In my case the oil pressure light came on and stayed on because the oil pump failed.
Oil pressure specs
2012 S model: Idle 10 PSI; 3000 RPM 16-93 PSI (MINI went with a variable pressure oil pump in 2011; OEM recommended oil 5W-30
2007 (not variable) Idle 10 PSI; 3000 RPM; 22-44 PSI; OEM recommended oil 5W-30
Old Feb 20, 2023 | 11:45 AM
Artik99's Avatar
Artik99
Thank you so much!
Old Feb 20, 2023 | 12:19 PM
mkov608's Avatar
mkov608
This is the master oil pressure kit I ordered.
Amazon Amazon
ostojo
Mar 9, 2022 01:43 PM
Euphonium
Jan 27, 2020 08:45 AM
tomsws6
Jan 24, 2020 08:38 AM
snowsports1
Jun 22, 2019 10:54 AM
hemiheaded18
Oct 2, 2008 02:51 PM
