R50/53 Belt Tensioner Shock available!
Has anyone else been frustrated by the belt tensioner shock's short life? That thing leaks oil within a year or two, then soaks its rubber bushings which rot out and the whole thing rattles around, then you gotta replace the whole dang tensioner for a hundred bucks! The tensioner isn't that easy to replace either.
I found the shock only, available at https://www.autohausaz.com/. P/N: UR-11288620210D. It's URO brand, we'll see how it holds up. Cost is 20 bucks. Also, you can replace the shock relatively easily!
The engine on my 2005 had been sounding kinda clattery and I suspected (hoped) it was the belt / tensioner. It was. I had purchased the delrin bushings for that shock at some point, and I think they contribute to the noise because unlike bonded rubber bushings, they have a little bit of play. One end was about .005" bigger on the ID which I think is from wear, so they had to be making a little noise. The shock was way past done as well, so who knows where the noise was really coming from, probably both shock and bushings. I put in the new shock with its stock rubber bushings, put the delrin ones in the spares box, checked the tensioner and idler pulleys for bearing issues (they were fine), installed a new belt, and oh man, it has that sweet purr again.
This tensioner design is a thorn in our sides IMHO. Most cars have much simpler ones that almost never go bad, other than the bearing occasionally. Why is this one so complex, spendy and has this weak failure point? But if I can just replace that shock every couple years for $20, that's not so bad.
Amazon had it for $73. Not exactly that pricey, considering what's involved.
If it fails again, I'll order one from FCP euro, pay the premium and have a free lifetime replacement.
https://www.fcpeuro.com/products/min...09476#warranty
Does it solve the issue with it failing or having to spend the time on repairing? No. But, it's a wear item and will fail eventually.
I found the shock only, available at https://www.autohausaz.com/. P/N: UR-11288620210D. It's URO brand, we'll see how it holds up. Cost is 20 bucks. Also, you can replace the shock relatively easily!.
Thanks!!
Angry - fair point, and the LTW is cool. For me though, I've seen that the shock wears out like 5x faster than the bearing, so I'm glad to be able to just replace that part.
Isk - from the top. This time I was in a little deeper for other reasons so I don't remember for absolute sure, but I think you can replace the shock without removing anything else except maybe that VSV that's right by the mount. Worst case, remove the upper engine mount. No, you don't have to take tension off the belt because you are only changing the shock. It's held on by a 13mm head bolt on each end. I think you can access the rear one from the top, behind the engine mount, and the front bolt from in front of it, with a 13mm box end wrench.
I just installed a replacement on Tigger ('05 MCS, 195k miles) from Pelican Parts, I also installed a set of Poly bushings while I was at it.
isk- I pulled the motor mount bracket to get at it, even then it was a bit of a contortionists act getting the lower bolt started. You don't have to mess with the tension or the belt to do this. Be sure to put a board between the sump and your trolley jack, the level of the engine is a key to easy reinstallation of the motor mount bracket, if the engine is higher or lower than the motor mount wants, the large 10mm bolts won't line up. If your cam position sensor is leaking, this is a good time to replace either the o-ring or the sensor as its right there.
HTH,
HTH,
that's odd, I've seen them for sale all over the place
That URO damper is also available at Rock Auto for ~$20
https://www.rockauto.com/en/catalog/...r+damper,11663
Litens was the oem of the tensioner back in the day.
https://www.northamericanmotoring.co...placement.html
11288620210D is good, never heard anything bad, stabilus i believe was oem which we carry. They make all the factory MINI hood and hatch struts.
https://www.ecstuning.com/Search/Sit.../11288620210D/
Jahboto
Jan 4, 2019 07:14 AM
GoThingNC
Dec 12, 2016 09:06 AM
mini_macky
Jan 18, 2014 03:19 AM
getthething
Jan 30, 2013 02:44 PM
