R56 Adjusting Xenon Headlights
Old Jan 25, 2023 | 01:18 PM
airbusA346's Avatar
airbusA346
After removing my Xenon headlights for them to be joey moded. I've now refitted them and obviously they aren't pointing in the correct direction and height.
Do any measurements exist that could be marked on a wall etc to make sure they are pointing in roughly the right place and at the right height?
Are the measurements meant to be made with weight in the car too?
Old Jan 25, 2023 | 01:48 PM
Here you go: https://www.northamericanmotoring.com/forums/stock-problems-issues/296223-r56-headlight-adjustment.html
https://www.northamericanmotoring.com/forums/electrical/263178-oem-xenon-25w-retrofit-kit-6.html
So what most people do is mark the old lights locations and distance.
Old Jan 25, 2023 | 03:00 PM
airbusA346's Avatar
airbusA346
Sadly I can’t create a mark using the lights.
Old Jan 26, 2023 | 08:04 AM
Gubi's Avatar
Gubi
Here are some good headlight aiming instructions. You need a very flat area with 25' of space for the car and a flat wall, though in a pinch I've done it in the garage with like 10". You just need to do the math to adjust for the different distance for vertical adjustments.
http://www.danielsternlighting.com/tech/aim/aim.html
I believe the Mini headlights are marked VOR which means you don't measure downward from the center marking on the headlight lens, but verify this.
Vkng
Nov 9, 2015 05:40 AM
Burkee52
Electrical
Jul 6, 2015 07:47 PM
