R50/53 Airbag Light Never Comes on
Old Jan 24, 2023 | 12:43 PM
DeeBeeCooper's Avatar
DeeBeeCooper
2003 Cooper S. My car failed its inspection today because the airbag light never comes on; not on startup, not with the key in any position, never. I suspect a previous owner probably found a way to tamper with it so they could either get it to pass inspection or sell it. Either way, I'm guessing I should start at the speedometer and work backward to find the issue. I have a fault code of 51 Lamp Fault when I look at the codes in the Multiple Restraint Section of my code reader. I don't see anything else that would be related to the airbag system. Any ideas?
Old Sep 7, 2023 | 03:38 AM
DeeBeeCooper
Hoping to bump this to see if anyone here has ever come across this?
Old Sep 7, 2023 | 05:56 AM
Boostmaster's Avatar
Boostmaster
Maybe the bulb was removed or it's blown?
Old Sep 9, 2023 | 09:25 PM
Onizukachan's Avatar
Onizukachan
There is no bulb. It’s LED. Either the LED failed which is new Speedo cluster time (or solder a new SMD in) , or someone coded the airbags out.
I suspect with the code, it’s the former.
Old Sep 13, 2023 | 07:11 PM
Onizukachan
Thread title sounds like a smiths song,btw.
Old Sep 14, 2023 | 05:33 PM
Daftlad's Avatar
Daftlad
"Bag light's out...tonight...
Checked my Bentley and Mod MINI and the N-A-M foooruuum...
Trying to smog this car, it's never ever going to pass...
Because it doesn't come on....anymore..."
I have a scanner and a fault code and the damn thing won't liiight...
Oni-zu-ka-chan...says 'check the L-E-D'
Because it's no light bulb, there's no light bulbs on an R53..."
"And if I had the heart...to pull the dash apart...
You know damn well the bloody thing would not start again..."
"This air-bag light will never come on...this air bag light will never come on..."
Old Sep 14, 2023 | 08:18 PM
Onizukachan
Beautifully done, and I totally read it in Morrissey’s voice, lol.
Old Sep 14, 2023 | 09:08 PM
Onizukachan
Here is the smiths song being referenced. Play it amd Sing along with the new lyrics… beautifully done!
Though I do feel like the ending chorus is about every r53’s dashboard…
Old Sep 15, 2023 | 03:35 AM
Daftlad's Avatar
Daftlad
"Check engine light will never go out...check engine light will never go out..."
Old Dec 14, 2023 | 06:29 PM
DeeBeeCooper
In case anyone ever runs into this, I figured it out. The car likely had a driver's door leak somewhere along the line, which I assumed damaged the 40-pin connector in the footwell. One of the PO's decided to cut it out and then rewire it incorrectly using cheap butt splices. I went wire by wire with the schematic, resoldering all of them. Now, everything works as it should.
Old Dec 15, 2023 | 09:17 AM
Daftlad's Avatar
Daftlad
"This airbag light, it finally came on...this airbag light, it finally came on..."
Old Dec 17, 2023 | 12:54 PM
RockC's Avatar
RockC
Good job of diagnostics and repair! You are the Champion.... of the world! (Apologies to Queen!)
Old Dec 18, 2023 | 12:50 AM
Onizukachan
Thanks for posting the solution, but might I recommend you also post it in your other thread?
kgardnez
Jun 3, 2022 03:25 PM
georgia
Jan 15, 2021 05:57 AM
moto_mini
Sep 9, 2012 11:16 AM
Rowan212
St. Louis MINI Club
Jul 11, 2011 06:51 PM
gazah
Dec 22, 2009 09:46 AM
