R50/53 Koni FSD lifespan
Old Dec 12, 2022 | 03:14 PM
Racingguy04's Avatar
Racingguy04
Koni FSD lifespan
Anybody know about how long KONI FSD's should last? I have a set with 70k miles on them with probably 12-20 track days and I'm wondering if they might be shot. I don't notice any wallowing and they pass the bounce test, but I've got a noise in the rear that I can't identify, and I've ruled out just about everything else
Old Dec 13, 2022 | 02:36 PM
Buggy's Avatar
Buggy
Good chance the top rear mounts are shot. Replace with Powerflex; that should help especially if the existing mounts are Lemforder. If you scroll through my posts you will see a thread on this issue with the noise from the rear shocks.
Old Dec 13, 2022 | 05:06 PM
Racingguy04
Originally Posted by Buggy;[url=tel:4639691
4639691[/url]]Good chance the top rear mounts are shot. Replace with Powerflex; that should help especially if the existing mounts are Lemforder. If you scroll through my posts you will see a thread on this issue with the noise from the rear shocks.
yeah, already replaced the oem ones with powerflex a year or so ago. I also replace the sway bar links. I’ve replace the lower control arms with adjustable ones, and the upper arm bushings look fine. I’ve thought about replacing the trailing arm bushings, but they look fine.
Old Dec 13, 2022 | 05:21 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Is the noise readily reproduced? What conditions produce the noise?
I wouldn’t be surprised if the shocks were done. Anything over 50k miles is usually bonus time for shocks.
Old Dec 29, 2022 | 04:20 PM
hamptup's Avatar
hamptup
I've got 75k on my Koni FSD and 11yrs street driven. Upon my alignment the mechanic said I should replace the lower control arms and ball joints cause I was getting a low speed squeak. I thought it also could be the Koni's are going out but the car suspension seem okay. So when do Koni's give up the ghost?
ASuman
Jun 12, 2014 06:54 PM
iporkgoats
Suspension
14
May 5, 2013 02:37 PM
blacter
Suspension
Feb 7, 2010 09:09 PM
