08 R56 with Factory Bluetooth...No "Phone" option in MENU...where did it go?
Old Nov 29, 2022 | 05:18 PM
Rommel's Avatar
Rommel
Been trying to research this one, and I'm at a loss.
I have an 08 R56 with the factory Bluetooth option. When I select MENU on the head unit, there is no "Phone" option. I confirmed the option on the build sheet, visually confirmed the microphone (and moved it to the Driver's side), and the MULF2 (no water intrusion noted). I also checked fuses in the passenger floorboard fuse box, and they were ok.
I have all the components, so why is there no "Phone" option when I select MENU? Could the computer or head unit have been swapped out for one that was not coded for Bluetooth?
Old Nov 29, 2022 | 07:44 PM
giorgos's Avatar
giorgos
Did you ever notice it being there or do you assume it should be there?
Which option did you find in the build sheet? There are separate ones for Bluetooth connectivity regarding calls (for which the microphone is fitted) and music streaming via bluetooth.
Old Dec 4, 2022 | 08:46 AM
Rommel's Avatar
Rommel
George,
Thanks for the response. Sorry for delay, took a few days to find the build sheet. Below are the codes.Phone module ULF2_HI
S645A BMW US Radio
S693A Preparation BMW satellite radio
S694A Provisions for BMW 6 CD changer
S6FCA Radio MINI Boost CD
S6FDA MINI HiFi speaker system
S6NEA Extended mobile phone prep. w/Bluetooth
I also ordered another used MULF2 matching the codes for our current one, inorder to R&R and see if it works. If not, I'm assuming I would need to chase the MOST bus line to see if and where the disconnect is...correct?
I haven't done a search for MOST bus testing (yet), but if you know of a quick how-to for testing the MOST bus, that would be much appreciated.
Old Dec 4, 2022 | 12:23 PM
giorgos's Avatar
giorgos
Since you didn't respond to the question:
Am I safe to assume that you never actually saw "Phone" as an audio input option on your radio?
I'm not aware of option codes starting with S and ending with A. Maybe they were different for the States.
However, the "middle" part of your (non-US) options corresponds to those offered in Germany. The title for 6NE here is:
6NE Extended mobile phone prep. Bluetooth with USB-Audio-Interface
i.e. for audio playback from a mobile phone, a USB connection is required.
Searching for 6NE on NAM further reveals:
Comfort Bluetooth/USB $6NE music via Bluetooth?
Old Dec 5, 2022 | 03:31 AM
Rommel's Avatar
Rommel
I've owned the vehicle for about 1 year, and in that time, the option "Phone" has never appeared.
The car does have a USB and Aux port located in the cavity under the center dash, infront of the stick shift, but I've tried multiple 2 wire connectors, and none have worked.
Through my research to date, it appears that if the option "Phone" or "USB" is not there, but all of the hardware associated is installed, then the car is likely no longer recognizing the equipment, and thus not displaying the options.
Old Dec 5, 2022 | 02:01 PM
giorgos's Avatar
giorgos
Source?
Have you checked whether the USB and AUX ports are fine individually (i.e. with a memory stick and a male-to-male headphone jack cable)? Did you try connecting an iPhone or iPod with a (working, see below) 2-wire connector?
My MINI LCI came with the option 6ND ("Hands free Bluetooth with USB-Audio-Interface") from factory. There is also an AUX port. The USB port can be used to read mp3 files off a memory stick. The AUX port also works on its own fine (e.g. connecting a phone's headphone output). Note: if nothing is plugged into either of the ports, there is no option offered to select them for input. Reading or playing mp3 files off a smart phone does not work via the USB connection. Nor does streaming via Bluetooth. Whether or not an iphone with a special USB+AUX cable would work I never got to try out.
According to the german price list from July 2011, option 6NE (yours) also includes a, quote:
"music interface for smartphone for a comfortable connection of mobile phones with integrated mp3-player (e.g. iPhone) inside the middle arm rest. A special Snap-In adapter with USB-Function for playing audio files in the mobile phone is required (available through MINI parts sales). ... The mobile phone and the Snap-In adapter are not included. ... A cable adapter for connecting an Apple iPod is available via MINI parts sales."
NHBert
Jun 11, 2015 09:56 AM
Rrotz
May 20, 2015 09:03 AM
Baypally
18
Feb 4, 2013 11:33 AM
symphosomatic
Electrical
Jan 4, 2008 08:01 PM
stealth
Dec 28, 2007 12:18 PM
