R50/53 No Compression on Cylinder 2
Old Nov 12, 2022 | 03:28 PM
Zeff's Avatar
Zeff
Hey guys,
My wife and I were driving home last night and on the highway the engine started running funny. Go it home and checked everything out today. I discovered it's lost all compression on cylinder 2. It has been burning oil for a while which may or may not be related.
Curious if those more experienced with this engine have a good guess what has happened. I would think it would be top end. But curious how catastrophic whatever happened would be?
This is a 2005 JCW. All stock as far as I know.
Thanks for your help,
Zeff
Old Nov 12, 2022 | 05:30 PM
Nervos's Avatar
Nervos
anything, really. Stuck or burnt valve, failed valve seat, a hole in the piston, crack in head or block, failed compression rings (less likely, though, if you don't have other weird noises from the engine).
Start with removal of the valve cover, inspect the valve stems, check if they move freely all the way. You may use a flex cable inspection camera through the spark plug hole, but you'd need the one that can "look back" as well as "front" (i.e. at the head, and at the piston). This way you could inspect if there are any debris on the piston, if the cylinder walls are damaged and if the valves are good or not (by looking back at the head).
But most likely you'd need to remove the head to figure out what happened.
Old Nov 12, 2022 | 06:52 PM
Nervos's Avatar
Nervos
You can do a leak down test to get more or less definitive answer what is wrong. You put cyl 2 in TDC, put a compressor into the spark plug hole and apply pressure. Listen where the air is coming from: 1) exhaust - issue with the exhaust valves, 2) intake - intake valves, 3) open the coolant expansion tank, bubbles - issue with the headgasket, 4) from the oil dip stick - rings, piston, block.
Old Nov 17, 2022 | 07:41 PM
Zeff's Avatar
Zeff
Update!
Burnt valve was the culprit. And, I discovered the camshaft is in terrible shape. Thankfully the cylinders look great. But man, the camshaft is a bummer.
If anyone out there has a good camshaft collecting dust, please get in touch.
Old Nov 18, 2022 | 04:40 AM
Daftlad's Avatar
Daftlad
Just curious how many miles on this car and what is its history before you owned it, if you know it?
Old Nov 18, 2022 | 05:45 PM
Zeff's Avatar
Zeff
It has about 160K.
Three owners as far as I know.
Owner before my wife notoriously bad at maintenance.
Someone installed woofers and an amp in the trunk so I think the first owner was pretty young.
Took the head to the machine shop today. They said it was rebuilt previously based on a tag attached to its side. Maybe that's why some of the exhaust nuts were loose...
Old Nov 18, 2022 | 07:36 PM
The Devil Z's Avatar
The Devil Z
I have a good used camshaft
I’ll have to figure out what’s what as it’s next to a
r50 cam so hopefully I can tell them apart. It’s cold as fork though in Wisconsin currently
Old Nov 20, 2022 | 10:26 AM
TRagic's Avatar
TRagic
FYI; Rock Auto has head gaskets for $16. Or you can get a bigger kit w HG, valve cover gasket, water outlet, valve stem seals, etc.
im in the middle of a new HG install, so I’m replacing every gasket and seal I can. No fun to have to pull stuff apart twice.
but not making much progress. It’s been to cold in Flagstaff. Highs in the 30’s w wind and snow. Yes, it snows in AZ!
Old Nov 20, 2022 | 01:53 PM
deepgrey's Avatar
deepgrey
Aren't the stock R50 and R53 cams the same?
Old Nov 20, 2022 | 06:05 PM
The Devil Z
Dont think so but would make it easier when I go out to look lol. It has been so long since I have seen a stock unit. I have 6 of various sizes on the shelf for various applications. Current is 300/288 lol
Old Nov 21, 2022 | 04:53 AM
Daftlad's Avatar
Daftlad
They are the same.
https://www.realoem.com/bmw/enUS/par...&q=11311485827
Old Nov 21, 2022 | 05:11 AM
Daftlad's Avatar
Daftlad
Old Nov 21, 2022 | 10:26 AM
The Devil Z
Cool OP if you want it pm me
Old Nov 26, 2022 | 10:11 AM
The Devil Z
Originally Posted by Daftlad
while the part number is the same the profile is intact very different. So real oem messed up that one. I checked with digital calipers as well as asked Kurt and Way
BRGNigel03
Sep 1, 2019 11:30 AM
speedmob
Jun 7, 2018 01:21 PM
Etmil35
Dec 18, 2017 10:24 AM
triplep2814
Nov 14, 2013 07:18 PM
nethack
28
Apr 26, 2013 01:52 PM
