New wheels online
Old Nov 5, 2022 | 04:07 PM
miniRogue1's Avatar
miniRogue1
New wheels online
If I purchased new wheels online, do I need to buy new TPMS sensors or can they use the ones currently on the car?
Every company wants to add them to the cart.
Old Nov 5, 2022 | 05:23 PM
RB-MINI's Avatar
RB-MINI
The sensors are mounted inside the tire, usually as part of the valve stem. If you’re getting a pre mounted wheel/tire combo, you’ll definitely have to get new sensors. If wheels only and re-using your old tires or buying new locally, you could possibly use your old ones. IMO, unless you know your old sensors are compatible with the new wheels (not always 100%), and you know the sensors/batteries are fairly new, I would just buy new sensors because I don’t think the batteries are replaceable. It would suck to use the original sensors only to have them die before the tires need replacing.
You should also be able to get new sensors locally if needed. Just make sure the new sensors are compatible with your TPM system because I’ve seen a few posts where the new sensors wouldn’t connect due to the frequency or some other communication issue.
Old Nov 5, 2022 | 05:28 PM
miniRogue1's Avatar
miniRogue1
@RB-MINI
thank you. Yeah if i do the combo I’ll definitely just buy the sensors. But thinking about just upgrading the wheels now. But of course that would probably cost me more for transferring tires and tpms and balancing as opposed to just mounting.
this was supposed to be cheap and easy. Oh well. .
puniphorous
Tires, Wheels, & Brakes
Nov 1, 2014 07:45 PM
Spectrum24x
Nov 24, 2012 05:01 PM
Willy723
Mar 22, 2009 09:04 PM
BeantownS
Nov 22, 2008 08:30 AM
buckoa
Oct 22, 2007 10:59 AM
