R55 Shake or vibration around 2nd gear after lowering
Old Oct 31, 2022 | 03:56 PM
jarthur's Avatar
jarthur
I recently lowered my 2012 R55 and I can't comprehend how doing so would produce the issue I'm having. I can start out in 1st gear (auto) just fine, no shaking or vibrations but as I accelerate normally it will shake around 2nd gear. I can't tell if it is the shift to 2nd or just speed related. The Shake seems less the more gas I give it (i.e. if i stomp on it, barely any shake). It is still very drivable, just annoying.
Maybe it is just a coincidence and my motor mount are bad, but if someone has ideas where I'd look, id appreciate it.
Lowered about 1.5" maybe.
Old Nov 1, 2022 | 05:22 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
The Clubman looks good! Which lowering kit did you go with? Your rear looks lower than mine, front looks about the same. I'm lowered on Megan Racing coilovers.
There have been multiple reports of driveshaft vibration after lowering going all the way back to early R53 cars. Some claim it to be imperfections in the axels. It's possible its motor mount related, but I couldn't tell you for sure. Not everyone that lowers their Mini experiences it. Mine never had any vibrations after lowering.
Old Nov 1, 2022 | 07:35 AM
RB-MINI's Avatar
RB-MINI
As stated above, imperfections in the axle is a theory I’ve seen a lot on the forums. If the axles are worn enough, a wear spot/groove forms. After lowering they supposedly vibrate due to running in and out, or at the edge of it due to the new angle of the u-joints. Kind of like what you feel in the steering wheel and car when the tires tramline on a bad road.
How many miles were on the axles when lowered?
Old Nov 1, 2022 | 08:16 PM
jarthur's Avatar
jarthur
Thanks, I'm running megans too. Probably will raise the rears 1/4 inch. Had some rubbing with a rear passenger last night.
Old Nov 1, 2022 | 08:19 PM
jarthur's Avatar
jarthur
I guess it could be the axle. Is it common to only happen at one specific speed point. I verified last night that it vibrates before/during/after 2nd shift. So probably not gear related. I have about 85k on the mini when lowered. Not sure if axles are stock or have been replaced before. Bought at 82k.
Old Nov 2, 2022 | 03:26 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
What are your wheel and tire specs? Size and offset?
Maybe try raising the front by 1/4” also to see if that changes anything?
Old Nov 2, 2022 | 10:32 PM
jarthur's Avatar
jarthur
Oz Italia 17x7 ET37, 215/40
Yep I'll prob raise a little
Doug Fowley
Jan 13, 2012 04:31 AM
A S K
Feb 22, 2010 03:16 PM
NMgokart
Jul 24, 2009 11:30 AM
minihune
SCCA Solo and ProSolo
11
Feb 11, 2007 04:10 PM
chrisneal
Feb 4, 2003 06:23 AM
