R50/53 2004 R53: Power Steering Fan Question
Old Oct 27, 2022 | 08:30 AM
Rebound's Avatar
Rebound
Hi!
When does the power steering pump fan engage? I want to make sure mine is operating correctly. Thanks!
Old Oct 27, 2022 | 02:39 PM
cooper48's Avatar
cooper48
The power steering fan engages at X temperature and that is controlled by the ECU. Example: Because I live in Texas where it's hot as hell in the Summer I had mine reprogrammed to come on sooner at a lower temperature. I've read a number of comments that says the A/C has to be on for it to work but I haven't tested that theory. It's an easy and cheap DIY fix (two bolts). New PS pumps are around $600 so the fan is a cheap alternative if you think it's not working. Remove the fan and see if the blades turn freely. You should also check the fuse just in case.
Old Oct 27, 2022 | 07:13 PM
Tiagovito's Avatar
Tiagovito
When you turn the AC on fan should go on as well. is a good way to test it, @cooper48 said is super easy to replace.
Old Oct 27, 2022 | 07:15 PM
Tiagovito's Avatar
Tiagovito
I didn't know I could be programmed, how do you go about that? Thank you
Old Oct 28, 2022 | 05:22 AM
Rebound's Avatar
Rebound
I’m not talking about the radiator fan; I’m asking about the power steering fan. I just want to know how to verify proper operation. So is the PS fan driven off the same circuit as the radiator fan?
So it triggers at an engine cooling temp of 221F?
Old Oct 28, 2022 | 10:56 AM
ChiefM's Avatar
ChiefM
I want to say yes.
Old Oct 28, 2022 | 11:06 AM
Rebound's Avatar
Rebound
Originally Posted by ChiefM
I want to say yes.
Thanks, I’ll test it with my scan tool and
see if it kicks in with the radiator fan.
nasomi
Sep 17, 2018 01:59 PM
Sajuuk Khar
Oct 4, 2011 06:06 AM
SCMiniGuy
Feb 4, 2006 08:36 AM
Nuvolari
Feb 26, 2005 07:19 AM
