R50/53 Mini Cooper S 2005 R53 Power Steering
Old Oct 15, 2022 | 12:05 PM
iss49698's Avatar
iss49698
Hi All, We have a 2005 Mini Cooper S 2005 6 speed 160,000 miles and when the vehicle is stopped (ignition turned off) I could hear a buzzing noise that appears to be coming from the power steering pump. After restarting the vehicle, I can easily drive it and steering appears to be fine. However, after driving onto ramps, I can feel the power steering pump vibrating when the ignition is off. Any thoughts on if you think this power steering pump has gone bad? I checked the fluid and it appears to be at the correct level. The power steering fan does not appear to vibrate. I disconnected the battery while I figure this one out. Thanks for your help. Greatly appreciated.
Old Oct 22, 2022 | 09:05 PM
cagersguy55's Avatar
cagersguy55
It should be replaceable under recall, my 05 with 210k was eligible when I called. I think they replace the whole system.
Old Oct 27, 2022 | 06:44 AM
Rebound's Avatar
Rebound
A simple thing to try: Check the fluid level and then, with engine running, turn wheel fully left then right three times.
Old Dec 19, 2022 | 08:07 PM
a2coopers's Avatar
a2coopers
PUMP turns on with key turn before cranking
Hi,
I have a 2005 Cooper S, original pump, 158K KM, I'm original owner and had the PS pump lines replaced in 2018, with advisory of sweat at the pump and have had it working fine since. It has recently gotten a bit louder but nothing out of the ordinary what I did notice is when turning the key to position 2 "ignition on" all the way before cranking the engine "position 3" it appears to power the PS pump, not normal and I am able to move the steering without the engine being on. The pump works perfectly fine just wondering if this electrical glitch is faulty internal wiring somewhere that can be resolved without having to replace the pump ? Any ideas would be appreciated.
It appears to be intermittent, normally turning the key makes small buzzing sound then all noises stop, all dash lights on etc, before turning engine on, but now it seems to be powering the power steering when turning the key just before ignition, and seems to stay on until I got back one position with the key.
Anthony
jarl66
Jul 2, 2019 11:06 AM
89325iturbo1
Aug 22, 2016 11:45 AM
Eleo
Oct 10, 2012 12:23 PM
Dale Jones
Oct 8, 2011 04:51 PM
orb451
Sep 29, 2006 10:30 AM
